Complete 2007 Camry Crash Test Results.. PERFECT! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-07-2006, 11:12 PM   #1 (permalink)
Toyota | moving forward
islandboy57's Avatar
View islandboy57's Photo Gallery
Thumbs up Complete 2007 Camry Crash Test Results.. PERFECT!
Camry is a top performer in the side impact test: The redesigned Camry is one of only six car models the Institute has tested to earn a perfect score in the side test. The Institute rates the risk of injury separately for the head, neck, torso, pelvis, and legs. Vehicle side structure also is rated. The Camry is good in all of these categories. For the 2007 model year, this car has standard curtain-style side airbags designed to protect people's heads plus separate side airbags to protect the torsos of front-seat occupants.
^ These results were on the local news tonight. Awesome! It was also rated "GOOD" (best possible score) for frontal impacts.
Toyota Camry
2007 models
results also apply to: 2007 Lexus ES 350
FRONTAL OFFSET TEST
OVERALL EVALUATION:
Test details:
The Toyota Camry was redesigned for the 2007 model year. Frontal ratings are assigned by the Institute based on a test conducted by Toyota as part of frontal crash test verification.
The frontal offset crash test ratings also apply to the midsize luxury/near luxury version of the Camry, beginning with 2007 models of the Lexus ES 350.
Restraints/dummy kinematics — Dummy movement was well controlled. After the dummy moved forward into the airbag, it rebounded into the seat without its head coming close to any stiff structure that could cause injury.
Injury measures — Measures taken from the dummy indicate a low risk of any significant injuries in a crash of this severity.
Additional features:
  • Side airbags: front and rear head curtain airbags and front seat-mounted torso airbags (standard on Camry and ES 350); rear seat-mounted torso airbags (optional on ES 350)
  • Driver knee airbag: a separate airbag in the lower instrument panel designed to minimize knee injuries in frontal crashes
  • Electronic stability control (optional on Camry, standard on ES 350)
  • Antilock brakes
  • Daytime running lights
Tested vehicle specifications:
  • 2007 Toyota Camry LE 4-door
  • Class: Midsize moderately priced car
  • Weight: 3,303 lbs.
  • Wheelbase: 109 in.
  • Length: 189 in.
  • Width: 72 in.
  • Engine: 2.4 L 4-cylinder
  • EPA ratings: 24 mpg city | 33 mpg highway
Can't put a price on safety..maybe I'll trade my gen 5.5 in for a gen 6.5 when the time comes
'05 2AZ-FE @ 47K miles | '95 1MZ-FE @ 92K miles
moving forward
[Gen 5.5 - OEM fogs / FormulaONE tint / OEM rims / LEDs inside and out / Viper 1002 / EchoMaster]
islandboy57 is offline   Reply With Quote
Old 08-07-2006, 11:22 PM   #2 (permalink)
2007 Titanium Camry CE
07i4's Avatar
View 07i4's Photo Gallery
You are right! I checked this morning and the side impact result was not available. Checked again and it is there. All G. If only the rear crash is also G...
Previous thread:
http://www.toyotanation.com/forum/t142516.html
07i4 is offline   Reply With Quote
Old 08-07-2006, 11:24 PM   #3 (permalink)
Under Reconstruction
Epsilon's Avatar
View Epsilon's Photo Gallery
Did they say anything about the engine dropping after a front impact collision?
Epsilon is offline   Reply With Quote
Old 08-08-2006, 06:43 AM   #4 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $462074
View BlackCamSe's Photo Gallery
Gen5
I kno that some toyotas do that..but do you kno if the 05 camry does?
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is offline   Reply With Quote
2007 Camry SE Hesitation...Danger! jimmy57 Camry & Solara Lounge 25 11-24-2007 04:57 AM
Overall Comparison: Toyota Camry XLE V6 v.s. Pontiac Grand P CamryLeb Camry & Solara Lounge 25 08-13-2007 10:55 PM
2007 Camry Owner Satisfaction Survey thoots 5th & 6th Generation (2002-2006 & 2007-2011) 0 05-17-2006 07:35 PM
I Test Drove A 2007 Camry XLE I4 Today!!! LunarMist 5th & 6th Generation (2002-2006 & 2007-2011) 36 03-11-2006 06:32 AM
camry 2007.. ( big pics of camry) CAMRY GLI 5th & 6th Generation (2002-2006 & 2007-2011) 6 02-14-2006 08:26 PM
