$2 fix for center console squeak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-12-2006, 12:26 AM   #1 (permalink)
FlopShot's Avatar
View FlopShot's Photo Gallery
Gen6 $2 fix for center console squeak
I picked up my TCH last week and immediately noticed the infamous center console squeak. After doing some research on this website on how to remove the pillar covers and the console cover, I found a quick and simple fix that nobody seems to have tried. So stop waiting for your dealer to try and fix this, it is very simple to do.
Go to your local hardware or home improvement store and pick up a $2 pack of small self-stick felt pads, the kind you stick on the feet of chairs so they don't scratch the floor. (I used 1/2" medium duty pads) . Then unscrew your shift knob, then remove the plastic pillar covers and the center console cover. I don't have heated seats so I didn't need to disconnect any wires. You will notice some empty room between the holes in the console plate. Place a couple of the felt pads in between the various holes, I only needed 4. (TIP - don't put a felt pad at the bottom of the console, or you won't be able to pop that part of the cover back in). Pop the console cover back into place. The pads will provide enough extra cushion that the cover will no longer rattle. It took me all of 5 minutes to do this fix, and my rattle was 100% cured.
Hope this helps a lot of you!
FlopShot is offline   Reply With Quote
The Following User Says Thank You to FlopShot For This Useful Post:
Zero1 (03-28-2011)
Old 08-12-2006, 06:05 AM   #2 (permalink)
PBM
Boob
View PBM's Photo Gallery
My gen 5.5 driver's side window/lock/mirror panel has an infernal rattle that i can't seem to pad enough.
PBM is offline   Reply With Quote
Old 08-12-2006, 02:50 PM   #3 (permalink)
Don't get mad. Get even.
El Tano's Avatar
View El Tano's Photo Gallery
Thanks for sharing..
El Tano is offline   Reply With Quote
Old 08-14-2006, 04:59 AM   #4 (permalink)
View diycamry's Photo Gallery
Any pics?
2007 Toyota Camry SE V6
diycamry is offline   Reply With Quote
Old 01-18-2011, 10:04 AM   #5 (permalink)
molson.david's Avatar
Gameroom cash: $293553
View molson.david's Photo Gallery
I used high tepm. grease on all clips and contact points on shifter panels and AC/ stereo unit. no squeaking any more...
IndianaBorn gen7 LE.
For sale gen 6:
MdxTSXr black shrouds 5K retro
OEM key with transmitter
2.4 transm.filter+gasket+WS.
2.4 K&N drop-in+cleaner and oil
molson.david is offline   Reply With Quote
Old 01-20-2011, 07:43 PM   #6 (permalink)
2007 Camry SE V6
Gameroom cash: $132790
View thrawnis's Photo Gallery
Like diycamry said, do you have any pics?
My Update Thread: http://www.toyotanation.com/forum/sh...d.php?t=319520
2007 Camry V6 SE | Blue Ribbon Metallic | UR Strut/Sway Bar | K&N SRI | Magnaflow mufflers | H&R Springs | TSW Cadwell 19x8 Wheels | 6000k HIDs | Reus Custom Sound System | Tinted Headlights | Smoked LED Taillights | More
thrawnis is offline   Reply With Quote
