Size of Front Door Speakers? - Toyota Nation Forum : Toyota Car and Truck Forums
post #1 of 16 Old 08-16-2006, 04:06 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Gen6 Size of Front Door Speakers?
Does anyone know the size of the front door speakers? I'm looking to upgrade and Crutchfield shows both 5 1/4" and 6 1/2".
2007 Toyota Camry SE V6
diycamry is offline
post #2 of 16 Old 08-16-2006, 10:20 PM
User, not a Loser
2007CamryXLE's Avatar
Quoted: 0 Post(s)
Maybe they both fit.
2007CamryXLE is offline
post #3 of 16 Old 08-16-2006, 10:31 PM
Quoted: 1 Post(s)
Gen6
6x9 with my JBL system.
6x9 with base system also per service manual.
njerald is offline
post #4 of 16 Old 08-16-2006, 10:36 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Gen6
That's what I thought. Now why would Crutchfield only provide 5" and 6" replacements?
I also spoke to a guy at Best buy and he said there are problems when upgrading the speakers with the JBL system. Can someone verify this?
I'm not too knowledgeable in this area so really not sure what to think.
diycamry is offline
post #5 of 16 Old 08-16-2006, 10:53 PM
Quoted: 1 Post(s)
Gen6
Don't know. The JBL are 2.2 ohm vs std. spkrs are 4 ohm.
njerald is offline
post #6 of 16 Old 08-17-2006, 09:47 AM
whitenoize's Avatar
Quoted: 0 Post(s)
You have to realize that the stock speakers are 6x9 BUT with very shallow basket\magnet depth.
If you were to pop in most aftermarket 6x9s, they would not fit because of the depth required.
This is why Crutchfield says that they do not have any 6x9s that fit the 07 Camry.
I personally would recommend that you replace the fronts with 6 1/2" Components.
You will probably have to have an audio shop cut some MDF adapters to allow the smaller diameter drivers to fit in the holes.
2007 Camry LE
Upgrades: Factory lip spoiler, Stainless Exhaust Tip, Hybrid Camry Grille, SE Center Console Bin, Stainless Door Sills and Gentex Auto-Dimming mirror with Homelink
whitenoize is offline
post #7 of 16 Old 08-17-2006, 11:08 AM
jjthenovice's Avatar
Quoted: 0 Post(s)
Gen6
If you have the JBL system, then check out this link on the JBL system it should answer most of your questions: http://www.jbltoyota.com/toyota_camr...advantages.asp
2012 XLE V6 Magnetic Grey Premium HDD Nav Smart Key
jjthenovice is offline
post #8 of 16 Old 08-17-2006, 11:15 AM
whitenoize's Avatar
Quoted: 0 Post(s)
Yeah, I gave this link in a thread last week.
Really everyone in this forum needs to know to search for topics first before starting a new thread. Geez...
Go back and skim the last three pages of threads and count how many threads exist on the topic of 07 Camry car audio.
It's amazing....
2007 Camry LE
post #9 of 16 Old 08-17-2006, 04:50 PM
Quoted: 0 Post(s)
It's amazing....
Really you guys are waay too sensitive on the issue of searching...if you dont want to answer a question you dont have too...just keep scrolling down to the next post...who cares if someone starts a new thread, its not a matter of life and death its a freaking forum. I do understand your point, but like I said you guys are way to sensitive about this.
Whitenoize..since most 6x9's dont fit in the new camry....do you recommend or know of any that do fit?
(hopefully this is not a question that has already been posed..)
black_cam2007 is offline
post #10 of 16 Old 08-17-2006, 06:47 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Does anyone know the difference between 2.2 vs. 4 ohm speakers? Will both work in the front door location of the JBL system Camry?
I'm not that knowledgeable, so keep the words short.
diycamry is offline
post #11 of 16 Old 08-17-2006, 09:21 PM
Quoted: 0 Post(s)
I need to know the answer to that too...!
post #12 of 16 Old 08-18-2006, 09:44 AM
Quoted: 0 Post(s)
The ohm rating is the resistance the amplifier sees from the speaker. The lower the number the higher the resistance. A higher resistance of 2 ohms will allow the amplifier to draw more wattage. You can place a lower resistance speaker rated for 4 ohms onto the JbL amp, but it will ony draw half the wattage it previously did. Since aftermarket speakers are already rated for higher wattage recommendations, it will probably sound flat. Your best bet would be to add a seperate amp and aftermarket speakers.
mikegett is offline
post #13 of 16 Old 08-18-2006, 10:08 AM
07 Camry SE V6
wilfredcruz's Avatar
Quoted: 0 Post(s)
the lower the number the lower resistance. the lower the ohm the more power you get from amp.
some amps are not stable below 2 ohms, but some will go down to 1 ohm
depending on how you connect your speakers, you could make the amp "see" 1,2,4,8 ohms, depending on what are you trying to achieve.
I have a 15 in sub with dual coils, connected so I get 4ohms, that way my amp gives me 800w rms matchin the sub capacity. thats why toucant just go crazy and conenct all speakes to one amp if you don't know what you are doing you could burn the amp and you system is not gonna sound good.
recommend you get aftermarket amp and speaker....
make sure that you speakers mact the amp RMS rating very close. @ the ohm s that you speaker will be.
do some reasearch online and you wil find out how to connect speaker in many different ways. so your amp produce what you need.
2007 Camry SE V6 /Leather/sunroof/JBL
Added: XM Sat Radio (Toyota), 18in Wheels (Rial), 3M Tints (35%), LED Interior lights. TRD Lowering Springs
Removed: Camry Se Badges
wilfredcruz is offline
post #14 of 16 Old 08-18-2006, 12:55 PM
Senior TN Member
Quoted: 55 Post(s)
You can also install a speaker with a higher ohm rating than what the amplifier is rated for, as in a 4 ohm speaker will work fine with the stock JBL amp, should you try to do that. The converse to that is that you cannot install a speaker with a lower ohm rating, as that can damage the amplifier.
If it sounds good enough (to your ears) then there is no real need for another amp. However, if you install aftermarket speakers and crank it too loud, they will try to draw too much power from the JBL amp and cause it to 'clip', damaging both the amplifier and the speakers. In an ideal situation, your amplifier should be rated to put out significantly more power than the speakers can handle...its just your job not to crank it high enough to blow the speakers.
Family Toyotas
82 Corolla 89 Corolla 91 Previa 93 Pickup 94 Corolla 95 Avalon 96 Camry 02 Sienna 02 Tundra 03 Tundra 04 Camry 05 Corolla 14 Corolla
gideon1331 is offline
post #15 of 16 Old 08-18-2006, 04:29 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Having read the above, I'm looking at a pair of JBL 2 ohm speakers from Crutchfield.
http://www.crutchfield.com/S-GxNIBE3...00&I=109GTO527
Will this work on my front doors? Will I get better sound than the stock?
diycamry is offline
User Tag List
Linear Mode Linear Mode
« Back
