07' Camry Paint/Clearcoat problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-17-2006, 01:44 PM   #1 (permalink)
chitty's Avatar
View chitty's Photo Gallery
Gen6 07' Camry Paint/Clearcoat problem
I just detailed my 07' SE (dark charcoal colored) and drove to Chicago. It had rained just a little that night and the next morning the car had this hardened layer over the whole car. As if someone had sprayed 7up soda over it. I wash it the next day and now I have little circles and spots eched into the clearcoat. I tried 3m's fine cut rubbing compound and that helped a little. Toyota looked at it as well. They said they would have to wet sand the whole thing a I don't think I want them to do that either. A Toyota rep will be looking at it in about 2 weeks.
Any thoughts?
I have 3000 miles on the car. Venture film (protective film)on the front end, tint, radar hardwired and a sub in the trunk.
The only thing I can think of is to swap this for another car.
chitty is offline   Reply With Quote
Old 08-17-2006, 01:56 PM   #2 (permalink)
Under Reconstruction
Epsilon's Avatar
View Epsilon's Photo Gallery
If you trade your Camry in, you're definately going to lose money. Be patience and ask various bodyshops for any solutions.
Epsilon is offline   Reply With Quote
Old 08-17-2006, 03:29 PM   #3 (permalink)
Don't get mad. Get even.
El Tano's Avatar
View El Tano's Photo Gallery
Warranty should tace care of it.... Let them figure it out until they get it right, they can give you a rental to drive around and let them deal with the problem, If you take it to another shop and te problem comes back they will not garantee the original paint..
Good luck
El Tano is offline   Reply With Quote
Old 08-17-2006, 04:19 PM   #4 (permalink)
View mtnet2000's Photo Gallery
Go buy the Mothers Clar Bar Kit, then use the cleaner wax the kit comes with, then a nice coat of Mothers Pure Carnuba Wax wait a day and use Turtle Wax Ice to finish it off
2007 Barcelona Red LE I4
mtnet2000 is offline   Reply With Quote
Old 08-17-2006, 06:59 PM   #5 (permalink)
View diycamry's Photo Gallery
Do you have any pictures, I have the same color as you.
2007 Toyota Camry SE V6
diycamry is offline   Reply With Quote
Old 08-17-2006, 09:28 PM   #6 (permalink)
2008 SE V6
thoots's Avatar
View thoots's Photo Gallery
Any thoughts?
Let me get this straight: You have 3,000 miles on the car?
You have washed and waxed and washed and waxed, you've used 3M rubbing compound, and on and on and on -- and this is the dealer's problem, even to the point of giving you a new car?
Gosh, I sure don't think so. If the paint was OK for most of those 3,000 miles, then, well, "the paint was OK." You must have gotten something on it. Not to say it was your fault at all -- some truck or factory might have been misting something that adhered to your car, unbeknownst to you until you tried to clean it the next time. Or something to that effect.
I would think that a competent detail shop ought to be able to help -- I'd sure try that before doing anything like sanding the clearcoat down. What you can do with rubbing compound and what a detail shop can do with their power polishers is night and day different -- at the least, take it to a reputable detail shop, and see what they think about the situation!
Oh, and if the dealer would agree to actually do something as part of the warranty, my eyes would absolutely bug out like this ->
All that said, "Good luck!"
thoots
thoots is offline   Reply With Quote
Old 08-18-2006, 12:36 AM   #7 (permalink)
2007 Titanium Camry CE
07i4's Avatar
View 07i4's Photo Gallery
I have similar experience after parking near a sprinkler overnight. I don't know when it turn on but the water spot has some sort of deposit in it and it is impossible to remove. I agree with thoots that I don't think the warranty would cover things like that.
As for the spots, they went away after half a year or so.
07i4 is offline   Reply With Quote
Old 08-18-2006, 06:52 AM   #8 (permalink)
Gameroom cash: $232150
View Joe B's Photo Gallery
Low cost option to try.
50-50 to 75% white vinegar to 25% water mix.
I've used this on tap water spot and bird crap stains with some success.
I agree with all of thoots' post.
'11 Camry Hybrid Classic Silver/Ash
Moonroof | NAV | Leather | JBL Audio | XM | Blue Tooth | OEM Remote Start | Michelin Primacy MXV4
'11 Honda CR-V EX-L w/NAV 4WD Glacier Blue/Gray
Leather | Remote Start | Fogs | Premium Sound | XM | Wood Dash | Michelin Primacy MXV4
Joe B is offline   Reply With Quote
Old 08-18-2006, 07:24 AM   #9 (permalink)
<Insert title here>
View YotaRunner4's Photo Gallery
This is from hard water. Hard water has a high content of minerals that can affect taste, and in this case, and maybe even in chitty's case, can leave residue on the surace of cars, dishes, mirros, etc. The "spots" are left after the H2O evaporates, and leaves the minerals behind. After this happens, it can be a pain to get them clean.
Chitty, do you use hard water when washing your car? My 4Runner is Anthracite Grey (very similiar to Magnetic Grey Metallic) and I try not to wash it when it is very sunny outside since I have hard water as well. The problem is when you use hard water, the sun can evaporate the water before you get a chance to dry it with a towel, and leave the little spots "etched" into the paint.
To take these spots off, I recommend re-washing using Dawn dish detergent and dry right away. Then use Meguilars Quick Detail to finish it off. If theya re still on there, then you will need to do a full blown wax and polish with an orbital polisher.
To get around this, user soft water to wash your car from now on (if you can). I had to redo my plumbing to get one outdoor spicket of soft water.
'08 Highlander Limited 4X4, Silver Metallic
'07 Camry SE, I4 AT, Super White, Moonroof Package
'97 4Runner SR5 4x4 - Sold 1/2/09 with 164K miles
YotaRunner4 is offline   Reply With Quote
Old 08-18-2006, 07:48 AM   #10 (permalink)
BigWillie's Avatar
View BigWillie's Photo Gallery
Gen6
These are the warranties that we got:
Basic Coverage: 36 months/36,000 miles (all components other than normal wear and maintenance items).
Powertrain Coverage: 60 months/60,000 miles (engine, transmission/transaxle, front-wheel drive, rear-wheel drive, seatbelts and air bags).
Rust-Through Coverage: 60 months/unlimited miles (corrosion perforation of sheet metal).
Federal Emissions Coverage: Components under the federal emission defect warranty are covered for 36 months/36,000 miles and specified major emission control components are covered for 8 years/80,000 miles. Specified major emission control components under emission performance warranty are also covered for 8 years/80,000 miles. In addition, emission performance warranty is applicable for 24 months/24,000 miles in states and local jurisdictions that require a periodic EPA-approved inspection and maintenance program.
California Emission Control Coverage: In California and any other state that adopts California emission warranty provisions, performance warranty and defect warranty coverage is applicable for 36 months/50,000 miles, and specific control devices are covered for 7 years/70,000 miles.
For complete details about Toyota's warranties, please visit www.toyota.com, refer to the applicable Owner's Warranty Information booklet or see your Toyota dealer.
In addition, there may be times when we will establish a special policy adjustment that will further defray repair costs. For details about the new vehicle limited warranty, see your Toyota dealer. And for complete details of Toyota's warranties, please refer to your Owner's Warranty Information booklet.
Even under the Basic Coverage (commonly known as Bumper-to-Bumper Warranty), Toyota won't claim responsibilty for your problem. It sounds like by forces out of your control, your car was exposed to some foreign corrosive matter, which Toyota would deem is your responsibity to get it fixed. You would have a better chance of getting your car insurance company to cover it.
Also, you say you detailed your car (or had someone detail it), I would think that whatever wax/sealant that was appied would have protected your paint against such damage. When I bought my Camry, knowing full well that the cleaning and "waxing" the dealer does for the delivery has next to NO protection for your paint, I put a couple coats of my own wax/sealant on. I recommend Collinite 476S Super Doublecoat Wax. Apply one coat, then on the following day add one more coat. Not only will car have "SUPER" protection from the elements, but the beading properties of this wax is incredible and its durability is among the better on the market.
For more help on taking care of your new car, check out this website below. Lots of helpful info and helpful people. I'm sure a good number of people here already know of this site. I used to detail autos for years, but still didn't know everything there is to know.
Autopia.org - The Style, Appearance and Show Community for Car Enthusiasts.
Unless people have money to burn, "buying" a car is an investment and you gotta take care of it. Technically, the bank owns it until you send in that last payment assuming everyone finances their vehicles.
BigWillie
Sorry, I got a little !
BigWillie is offline   Reply With Quote
Old 08-18-2006, 09:28 AM   #11 (permalink)
View mikegett's Photo Gallery
I have the same problem with hard water. I too found Dawn to be the best alternative to car wash. It seems to break down the mineral spots much better. As he stated, avoid any contact with direct sunlight while washing and drying. I don't have any shade at my home, so I drive directly to the park for a quick dry and wax. The only difference is that I use Mequires gold class liquid wax.
mikegett is offline   Reply With Quote
Old 08-18-2006, 10:51 AM   #12 (permalink)
View Camry005man's Photo Gallery
Good luck
That's right. Leave it for dealer (Toyota). WARRANTY.
Camry005man is offline   Reply With Quote
Old 08-18-2006, 12:21 PM   #13 (permalink)
chitty's Avatar
Gen6
I will try to take a picture of the spots this weekend. If they will show on the camera.
The spoting is not from hard water. At my home I have a desinated water spiqot that is hooked up to my water softner. Then I have the filtered water sprayer and the car is only washed in the afternoon in the shade. I have had mineral deposits from hard water before and those I can handle and remove. The only time I have seen something like this before is when I had a car repainted with a Glaserat clearcoat and when bird poop would sit on it for more than one hour it would etch itself into the clearcoat. The only thing that would remove it with that car was the 3m rubbing compound.
I use a professional orbital and never get swirls. The rubbing compound really only works with a orbital. The Toyota detail shop tried it as well and could only fix it as well as I did. But the etching is still slightly visable. So that is why the Toyota rep will be coming to take a look at it. Every 07' Camrys paint must be F'd up in Chicago.
Old 08-18-2006, 03:36 PM   #14 (permalink)
2008 SE V6
thoots's Avatar
Yeesh!
OK, if you've already used power tools on the thing, that's a whole different story!
Beyond what you've already done or are heading towards, you might indeed head for autopia.com or other detail forums, and see what those guys have to say -- if you haven't already. Gosh, someone must have run into this kind of thing before, and ought to be able to tell you what they did about it....
Again, good luck!
thoots
Old 08-18-2006, 04:09 PM   #15 (permalink)
clasnipetya's Avatar
View clasnipetya's Photo Gallery
If any of you live in teh chicagoland area my friend is a very dedicated detailer and you can save time and money and just go to him.
He does an amazing job and people with Lambo's Ford Gt's and even Porsche's let him detail there cars.
He is most carefull and most knowledged about any litte thing that can be put under the category of detailing.
clasnipetya is offline   Reply With Quote
History of the Toyota Camry Ratko Camry & Solara Lounge 54 01-13-2012 09:42 PM
Newbie w/ 07 Camry ?? SevereCamry 5th & 6th Generation (2002-2006 & 2007-2011) 31 06-24-2006 10:36 PM
'07 Camry........or '02 ES300??? redgtxdi 5th & 6th Generation (2002-2006 & 2007-2011) 9 12-18-2005 04:11 PM
2004 Camry V6 tranny problem. Chigga 5th & 6th Generation (2002-2006 & 2007-2011) 5 03-30-2005 09:31 AM
How to tell if a 97-up Camry 4-cyl has the sludge problem? 93 Camry LE V6 3rd & 4th Generation (1992–1996 & 1997–2001) 4 03-01-2004 07:40 PM
