Calling out to fellow HID retrofitters for assistance - Page 7 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-06-2006, 06:02 PM   #91 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $186325
View JSM1284's Photo Gallery
I just ordered a set of TSX projectors for my GEN6 Retro.
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Old 12-06-2006, 06:07 PM   #92 (permalink)
Gameroom cash: $283730
View LE05's Photo Gallery
good choice! i can't wait to redo my retro with TSX's and OEM headlights this spring... my current depo headlights are ok but still have that cheap feeling.
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is offline   Reply With Quote
Old 12-06-2006, 06:35 PM   #93 (permalink)
I Want My MPG
View sn1cko's Photo Gallery
Gen5
Originally Posted by LE05
diode is not needed for our cars... low beam stays on when the high beams are activated. the diode is used to provide power to the low beams for cars that do not keep them on when high beams are activated... and also protects the high beam circuit from the backlash of power when the high beams are deactivated and low beams reactivated.
to "disable" the DRL activation of the solenoid, use two 5 pin relays. one relay switches the ground for the solenoid and is activated by the low beam or parking light. the other relay switches the positive for the solenoid and is activated by the high beam (this second relay may not be necessary... you can tap the high beam positive for the solenoid positive if 12 V is ok). by doing it this way, when DRL is on and low beams/parking lights are off, there is no ground to the solenoid. when low beams/parking lights are on (ground to the solenoid is on) and you hit the highs (positive to solenoid is on), you get "holy shit, thats a lot of light" mode... aka overkill
good luck with the bi-xenon retrofit... could be difficult fitting the solenoid in.
Thanks! Definitely gave me some ideas! I can't visualize the setup you've proposed yet, but I thought of something simple. It looks like I'm going to use two relays to 'disable' the activation of the solenoids by the DRLs. It'll require that both 9006 and 9005 are on to power the solenoid, else off; basic series kind of thing. Anything wrong with this set-up?
sn1cko is offline   Reply With Quote
Old 12-06-2006, 08:17 PM   #94 (permalink)
looks good, pretty much the same idea i had. what i described was basically your setup, but "paralleling" the relays, one for pos, the other for ground. if you find out what voltage the solenoid is ok for, you may be able to get away with one relay on the neg side and just plug into the stock high beam harness for the pos.
2005 Camry "LE"
Old 12-07-2006, 11:49 AM   #95 (permalink)
I Want My MPG
So it looks like I'll be using two relays total. The wiring looks like...
*ground wires omitted for simplicity of diagram
DRLs won't switch solenoids, because low beams won't be on during DRL.
Low beams alone won't switch solenoids, because relay on right won't be on.
I've seen Fuse 1 = 30A, Fuse 2 = Fuse 3 = 15A.
Are these numbers okay?
Will I need to change the values and/or put in more fuses because of the solenoid circuit?
Old 12-07-2006, 04:07 PM   #96 (permalink)
numbers look ok... you won't need to go any higher than 15A for the ballast fuses or 30A for the battery feed fuse. solenoids do not draw that much power... you may wish to put a fuse on the solenoids anyway just in case, but its highly unlikely that you'll need them.
2005 Camry "LE"
The #1 Techone HID Kit 6000k/8000k/10000k/12000k... $250 SHIPPED! Mod-Express Supporting Vendor Sales 53 11-27-2007 12:38 PM
Consumer Reports on HID Phi General Discussion 28 01-17-2007 08:23 PM
HID Kits Questions (56k Warning) AznVR4 Camry & Solara Lounge 29 06-29-2006 10:10 AM
