Originally Posted by Camralon2343
after i wax my black 05 Le it always has swirls. What u have to do is wet it and dry it with a shammy and u will get the best shine u have ever seen. After i waxed it last week someone with the 2006 and same color and with less miles than mine had actually asked me how i found a new leftover 2006 Camry. When i told him it was an 05 with 18,000 miles on it his mouth fell to the ground. lol
Thanx for that tip, i'll wet it in a few and see how it turns out. I just don't have a buffer or anything to work it in enough. So you can see the wax not blended in.
Originally Posted by 2007CAMRYXLE
Does your bumper have chips in the paint, or is that stuff on the bumper? The rest of the car looks good.
It was from bugs where the acid burned off the paint
I didn't know how to properly wash it so I chipped it up. Also, the cement trucks threw a ton of rocks at it too .
Originally Posted by atticdog
If you want to learn about proper detailing technique check out www.autopia.org swirls are mostly from improper washing technique
I'm not sure if it's those kind of swirls. I only see it when i'm using a wax or something. It's when I can't work it in enough so that it disappears completely.
Originally Posted by arcimpulse
im still loving the rims you got w/ the toyota center caps
yeah i could have kept the Lexus symbol on it, but that would've been odd.
-Custom 2.5 Exhaust + Weapon R Dragon Intake + TRD Rear Sway Bar
-Big 3 + Grounding Kit + TRD Springs
