Where is the side marker light wire? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-20-2006, 11:11 AM   #1 (permalink)
The Naive Voice of Reason
thapranksta's Avatar
View thapranksta's Photo Gallery
Gen5 Where is the side marker light wire?
That is my question. Also what color is it? Thanks.
Old Car: '03 Toyota Camry LE
New Car: '04 Black ES330 (Aftermarket sound/navigation system installed)
Always got something else in mind...
thapranksta is offline   Reply With Quote
Old 08-20-2006, 07:39 PM   #2 (permalink)
bump......need help immediately
Old 08-23-2006, 11:46 AM   #3 (permalink)
Mighty Flying Family Sedn
View Mighty~Mart's Photo Gallery
i'm surprised no one replied... i'd like to know this as well... maybe you can find it in the sticky repair manual.
Mart~
Camry Gen 5 SE
2.4L I4 DOHC
Stock 16's
Totally stock
Mighty~Mart is offline   Reply With Quote
Old 08-23-2006, 12:28 PM   #4 (permalink)
Unhappy
Yeah, that is pretty messed up. I know someone knows the answer with all the people installing fog lights and different lighting on their cars. I was installing fog lights on my car with the one-piece bumper. So cutting was trouble enough. I had a lot of trouble with the wiring under the dash and I changed the plans of my project from the aftermarket switch. I'm going OEM now, more money but less pain. I didn't really see anything in the sticky specifically for the Gen 5.
Old 08-23-2006, 02:07 PM   #5 (permalink)
see http://toyotanation.com/forum/t132391.html
Mart~
Camry Gen 5 SE
2.4L I4 DOHC
Stock 16's
Totally stock
Old 08-23-2006, 03:00 PM   #6 (permalink)
Thanks.
EDIT: Never mind. I see how you use it now. It just takes patience.
Old 08-28-2006, 03:09 AM   #7 (permalink)
View mrxbobert's Photo Gallery
Gen5
could you post pics of your install when you're done
mrxbobert is offline   Reply With Quote
Old 08-28-2006, 12:13 PM   #8 (permalink)
If you mean the fog lights, then sure I can post pics. My fogs aren't in there super clean but they are clean enough. I think all of my parts will arrive today so I will probably install everything today or tomorrow.
Old 08-29-2006, 02:00 AM   #9 (permalink)
yes! pics of the foglights would be awesome. from your other posts, i think you got the aftermarket kit from ebay....i'm curious as to how you mounted it on the bumper.
Old 08-29-2006, 03:28 AM   #10 (permalink)
Camry Gen5er
zettahertz's Avatar
View zettahertz's Photo Gallery
I just got some fogs from ebay 2 days ago. Got the horrible US bumper... Used dremel to cut the hole, shove it in and glue it w/ JBweld + hot glue.
2002 Camry LE I4 4AT
Spoiler, front strut bar, 17" wheels, Viper 791xv remote start alarm, Injen SRI, 50%-15% tint, TRD Exhaust, Tein S-tech, NST pulleys(underdrive + accessories), Whiteline RSB, HID+TSX projector retrofit.
2007 Nissan 350Z Grand Touring 6MT w/ Navi
zettahertz is offline   Reply With Quote
Old 08-29-2006, 03:39 AM   #11 (permalink)
That's basically what I did as well. Instead of JBWeld + hot glue, I sanded and used industrial strength epoxy (2500 lbs. strength). I guess it doesn't really matter as long as you get good strong and durable glue. It takes a while if you want to get everything right but if you take your time it is not hard at all.
BTW, I got my fog relay today and installed it. I had to fit my hand in the little crevice under the dash but the relay fit like a charm. I am now waiting on the OEM headlight switch w/ fog option.
I'll still post pics when I get everything together unless you don't mind seeing non-functioning fog lights. lol.
zettahertz, how's the retro?
Old 08-29-2006, 04:00 AM   #12 (permalink)
Camry Gen5er
zettahertz's Avatar
still working on the aiming, screwed up and cracked a reflector almost in half when trying to take it outta the housing... But JBwelded it back together. got all the parts, somehow the bezel I got is slightly different from yours, have to dremel it to fit the bottom part of the projector and the hole is a bit wider? Hopefully finish this thing this weekend. The aiming really frustrates me. It's almost done, was a bit confused with the cutoff line cus the right side dips a bit down right after the Z shaped thing and then curves slightly up at the right side (result of the color modding). Dunno how some ppl got it so straight.
http://home.comcast.net/~zettahertz/tsxprojector.jpg (blurry pic but u can see that dip)
But that dip is normal according to several ppl at HIDplanet so i guess it's fine. So I just tried to minimize the curving by placing washers in other locations and retain that blue colored line.
man, can't wait till this thing is finished.
Old 08-29-2006, 04:11 AM   #13 (permalink)
I'm a perfectionist sometimes and my lens do not match. One was sanded and buffed, its clear but it looks hazy. The other was not sanded and it is chipped up a little but clear and not hazy. So this is my dilemma before mounting the ballasts. Then I will be done.
Old 08-29-2006, 07:37 PM   #14 (permalink)
Here are a few pics:
My car from a distance (Yes, it's not very clean)
Close view of fogs. I can get closer but it pretty much looks completely stock unless you are really, REALLY trying to spot something that looks off.
The actual fog light switch (if you want to go OEM), very easy install
Lights on (sorry, it's daytime) If I'm not too busy, I'll take night shots as well
A random pic of my interior w/entertainment system. Why? Just cause.
After I install my hid retro, my exterior lighting will be complete and I will no longer have those "soft" LE headlights. Any questions?
Old 08-29-2006, 08:58 PM   #15 (permalink)
that looks great! so the glue holds up ok against all the shaking and whatnot the bumper goes through?
swap blue86supra Supra Forum 5 06-21-2006 10:23 AM
1985 Pickup starting problem...HELP twinturbonoy Pre-88 Toyota Pickup/Hilux 10 03-15-2006 02:25 AM
Side Marker Turn Signal Mod JPR94 Camry & Solara Lounge 4 12-11-2003 12:26 PM
