Shift Flare Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-21-2006, 02:43 AM   #1 (permalink)
Old TN Member
View reyrey127's Photo Gallery
Gen6 Shift Flare Question
Hi,
Does the shift flare tsb fix the shifting spikes that many of the owners here have stated? It would be great if someone could verify that the TSB fixes this transmission issue that many have discussed. Thanks
reyrey127 is offline   Reply With Quote
Old 08-23-2006, 09:46 AM   #2 (permalink)
Camry 07 SE V6 MagGry
View Sarge07's Photo Gallery
I would be very interested to know if the TSB fix works as well. I just took my V6 SE w/ 925 miles in yesterday for that exact problem. The onbly time I would get a spike in RPM was through the first and possible second cycling of the gears and it was always between 3rd and 4th, never experienced the problem when the engine was running at normal temps. The technician told me that he has seen the fix work, but it would be nice to be assured by members on this board that actually experienced the fix.
Sarge07 is offline   Reply With Quote
Old 08-23-2006, 12:49 PM   #3 (permalink)
View urotsukidoji's Photo Gallery
Don't get the TSB done if your car is not exhibiting the "shift flare", you risk ruining the performance of your car, that's just my 2 cents. Warming up the car seems to be the safest fix for some people.
urotsukidoji is offline   Reply With Quote
Old 08-23-2006, 01:40 PM   #4 (permalink)
I am definately experiencing the flare. The TSB states this occurs during "cold starts" not during normal operating temps.
Old 08-23-2006, 02:10 PM   #5 (permalink)
Under Reconstruction
Epsilon's Avatar
View Epsilon's Photo Gallery
No offense, but why not let your Camry reach normal operating temperature before driving it?
Epsilon is offline   Reply With Quote
Old 08-23-2006, 03:27 PM   #6 (permalink)
None taken, If you have noticed, I live in Michigan not Louisiana. If I were to wait until my vehicle reached normal operating temperatures in the winter I'd have to sit in an idling car for about 10 minutes before I could drive anywhere, that is not how vehicles are designed/engineered to operate. The reason the TSB was issued is because the vehicle is not performing the way it was engineered to perform.
Old 08-23-2006, 03:49 PM   #7 (permalink)
View crabjoe's Photo Gallery
Will the transmission fluid ever reach operating temp if the vehicle isn't moving?
I can see it getting a little warm, but I doubt it would get hot enough.
crabjoe is offline   Reply With Quote
Old 08-24-2006, 03:13 AM   #8 (permalink)
Old TN Member
has anyone done the TSB yet??
pleaseeee....
Old 08-24-2006, 08:48 AM   #9 (permalink)
Reyrey127...
Service Manager told me my car would be ready today or tomorrow. I will report back regarding the TSB fix for the 3rd-4th gear shift flare.
Old 08-24-2006, 09:42 AM   #10 (permalink)
Old TN Member
thanx sarge.. awesome...
hope your problem gets fixed.
Old 08-24-2006, 05:45 PM   #11 (permalink)
View black_cam2007's Photo Gallery
I would also like to here more input for the 4 cyl owners with at least 1500 mi on the car. Are you guys also having hesistation issues.
I ordered my 4cyl and it should be here tomorrow, but I may change my mind if this is a major issue. Most of my driving will be city so I cant deal with a hesistation between lower gears..
black_cam2007 is offline   Reply With Quote
Old 08-24-2006, 06:02 PM   #12 (permalink)
View Winterpeg's Photo Gallery
Canada
Can you tell me how warm/cold your car is when this occurs? I have an SE V6 and when I start out in the morning, I go through 2 shifts in my neighbourhood(not sure if it ever gets to 4th gear) before I enter a "high" speed street. When entering the higher speed street, the car has been running for about 4 minutes and the temp gauge has started to move. Never had the RPM spike and I have watched the TACH and counted shifts!
BUT, I live in CANADA where we have real winters and I guess I will have to wait until the temperatures get colder to see if I have the spike.
The tranny runs great and only a few rattles and the trunk lid needs to be adjusted which are minor.
Have a great day;
Winterpeg is offline   Reply With Quote
Old 08-24-2006, 09:00 PM   #13 (permalink)
Don't get mad. Get even.
El Tano's Avatar
View El Tano's Photo Gallery
TSB ??????? Excuse my ignorance, but what is that???
El Tano is offline   Reply With Quote
Old 08-24-2006, 09:05 PM   #14 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
Technical Service Bulletin.
From Toyota to their dealers, repairs, info, procedures.
Old 08-25-2006, 10:04 AM   #15 (permalink)
Have a great day;
You very well may not be getting into 4th in your neighborhood. I have to speed to do it. Outside temp doesn't really matter, the engine temp gauge has typically been less than a quarter of the way from bottom. Hopefully you will continue having a spike free tranny. I was hoping that the problem would go away but it just didn't and actually appeared to get worse. Car is still at dealer, may be ready today. Will report back on fix.
1st issue with 07'Camry AESANTIAGO 5th & 6th Generation (2002-2006 & 2007-2011) 949 01-08-2008 03:49 PM
2007 Camry SE V6 Performance/Traction Control wireless 5th & 6th Generation (2002-2006 & 2007-2011) 6 04-22-2006 02:37 PM
Performance chip for 2004 Camry SE 3.3L V6 5A? wesleyjwilson 5th & 6th Generation (2002-2006 & 2007-2011) 12 01-27-2006 04:40 PM
v6 se engine 05Cam-Weasel Camry & Solara Lounge 11 01-17-2006 07:20 PM
