Possible to have 15" tires on Camry 2007? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-21-2006, 07:08 PM   #1 (permalink)
View cimetiere's Photo Gallery
Canada Possible to have 15" tires on Camry 2007?
Hi! I own a Camry 2007 which has a 16" michelin tires on it. Since I had
previously a Camry 2002 with brand new winter tires on it, however, 15"
only, I was told that it is possible to buy 15" rims and put my 15" tires on
it. Would this fit my 2007 Camry? Is it something you would not recommend
me or is this ok? Any advise?
Many thanks!!
Daniel
cimetiere is offline   Reply With Quote
Old 08-21-2006, 07:15 PM   #2 (permalink)
Gameroom cash: $232150
View Joe B's Photo Gallery
I wouldn't do it.
I think you'll have a problem with your tire air pressure monitoring system.
Possible warranty issue also.
'11 Camry Hybrid Classic Silver/Ash
Moonroof | NAV | Leather | JBL Audio | XM | Blue Tooth | OEM Remote Start | Michelin Primacy MXV4
'11 Honda CR-V EX-L w/NAV 4WD Glacier Blue/Gray
Leather | Remote Start | Fogs | Premium Sound | XM | Wood Dash | Michelin Primacy MXV4
Joe B is offline   Reply With Quote
Old 08-21-2006, 07:46 PM   #3 (permalink)
Don't get mad. Get even.
El Tano's Avatar
View El Tano's Photo Gallery
Deffinelly not something that I would recomend but help yourself. Just check the size of the 15" with the 16" and see how much difference you have. Because if you have 215/60 16 and want to put 205/65 15 the difference will be about 1/2 inch on the overall wheel diameter. Here there is a link with the tire calculator, It will give you all the necessary information, diameter, speed, wheel revolution per mile, etc. About the the tire pressure sensor you can install them on the 15" wheels and that's it, because you will be running a 30 psi anyway with the 15".
Good luck
http://www.net-comber.com/tirecalc.html
El Tano is offline   Reply With Quote
Old 08-21-2006, 07:47 PM   #4 (permalink)
View frosty vibe's Photo Gallery
Canada
Originally Posted by Joe B
I wouldn't do it.
Warranty issue? Can you elaborate a bit?
I am planning to use 16" for my 2007 SE.
Thank you.
frosty vibe is offline   Reply With Quote
Old 08-21-2006, 07:53 PM   #5 (permalink)
Thank you.
If he happens to have a problem with anything related to the wheels,Toyota may void his warranty on the repair.
Smaller tires for the mosrt part will cause more tire revolutions which will cause problems for the tire presuure systems.
May not be a big deal but I wouldn't do it while the car is in warranty.
The car is set up for 16" tires and in your case 17" tires.
Just my .02.
Old 08-21-2006, 08:04 PM   #6 (permalink)
El Tano's Avatar
Just my .02.
Doesn't the tire pressure sensor works with pressure and not revolutions???.
The warranty definelly will be void, since those are not the recommended size.
Old 08-21-2006, 08:09 PM   #7 (permalink)
Originally Posted by El Tano
Doesn't the tire pressure sensor works with pressure and not revolutions???..
I believe the system works off the antilock brake computer with revolutions..
The vehicles with better systems actually read and relay lb pressure to dash readout.
I may be wrong but that's what I've heard.
Old 08-21-2006, 08:29 PM   #8 (permalink)
El Tano's Avatar
huuummm, you may be right, Ill try to find more info about that, now you got me curious....
Thanks
Old 08-21-2006, 09:19 PM   #9 (permalink)
View crabjoe's Photo Gallery
The tire pressure works by pressure not by revolutions. Also a deflated tire will spin just as many revolutions as an inflated tire per a given distance.
As for using 15" wheels on a a vehicle that came with 16"er's, it makes no difference as long as the outter tire diameter is the same. You could even go to a 14" wheel or even larger wheels. Being that the trick is to make sure you have the proper tire diamater, make sure to check the tire height. If I were switching, I'd look for a tire that might be ever so lightly larger to try and reduce the miles that appear on the odo. But remember, with larger tires, you'll lose acceleration, with smaller tire, its the opposite. Also, you might have problems with the shift points on your tranny. Most systems are setup to shift at a given rpm.
BTW, if you do change tire sizes, you might want to check with Toyota about having your speedo recalibrated. It might be as easy as them using a scan tool to change the # of revolutions per miles or you might need to change out a gear for the speedo. The odds are it's just using a scan tool. Doing this will not only show you the correct speed, it'll make sure that your tranny shifts correctly.
crabjoe is offline   Reply With Quote
Old 08-22-2006, 09:47 AM   #10 (permalink)
Gen 4 XLE v6
jhbhatia's Avatar
View jhbhatia's Photo Gallery
Nope, your rotor diameter will not fit 14's.
Desi Toyota Dude Here!!!
jhbhatia is offline   Reply With Quote
Old 08-22-2006, 12:18 PM   #11 (permalink)
Well I was partially right.
"Public Citizen and other consumer groups sued the federal agency, saying the rule was weak because it allowed automakers to choose between cheaper "indirect" monitors that work off the antilock braking system, or more accurate "direct" systems that have monitors in each wheel."
http://www.theautochannel.com/news/2...13/168576.html
Old 08-22-2006, 12:30 PM   #12 (permalink)
El Tano's Avatar
Sorry Cimetiere that we took your tread to a different direction, but I think that this issue is relevant. Thanks Joe B, you are right there are different ways, I found this online http://www.aa1car.com/library/tire_monitors.htm .
Thanks Joe b for mak it clear and sorry again Cimetiere.
Old 08-22-2006, 12:44 PM   #13 (permalink)
Thanks,El.
Cimetiere
At least you know your tire pressure monitor won't bew affected with the new Direct type of indicators.
Old 08-22-2006, 02:59 PM   #14 (permalink)
pjp
pjp's Avatar
View pjp's Photo Gallery
Canada 15" steelies
I wouldn't do it.
AFAIK Canadian 2007 Camrys do not have a Tire Pressure monitoring system. Not even the XLE. I think you just have to make sure your brake rotors will not rub on the inside of those 15inch tires.
I don't know if ABS would be an issue as long as you replace all 4 tires or that they all have the same outer diameter (OD).
07 Camry SE I4 auto
pjp is offline   Reply With Quote
Old 08-22-2006, 09:20 PM   #15 (permalink)
Thanks everybody!
pjb - According to the booklet I got from toyota canada, it does say that the tire pressure is taken. Is this a mistake??
Can I conclude I would not see any difference regarding traction and compfort between 16" and 15" tires?
Many thanks again!!
Regards,
cimetiere
History of the Toyota Camry Ratko Camry & Solara Lounge 54 01-13-2012 09:42 PM
Full Test: 2007 Toyota Camry Hybrid Tideland Prius Toyota News 5 12-06-2007 02:34 PM
Complete 2007 Camry Crash Test Results.. PERFECT! islandboy57 5th & 6th Generation (2002-2006 & 2007-2011) 3 08-08-2006 07:43 AM
2007 Trd Nascar Camry dieseltrooper 5th & 6th Generation (2002-2006 & 2007-2011) 7 07-01-2006 03:09 PM
