Ok so my mom just recently purchased a 2002 Toyota Camry LE 2.4L L4. The car has 61,000 miles couple of questions/concerns.
1.) The brake pedal seems to travel a bit further than usual and when I brake hard right before I come to a stop the brakes squeel for a quick moment. I also sometimes feel pulsation.
2.) With the A/C on "COLD" setting, recirculation, and the vent set to FEET or Down position. The position in the middle right after the Face only and Face and Feet only position. I BARE feel any air coming from the bottom vents I feel it coming a lot more from the defrost, and side vents on the driver and passenger side. The in cabin air filter was quite dirty, I cleaned it very thoroughly installed it and still notice very minimal air coming from the vents underneath the dash. Also with the fan setting on the highest when I switch from the feet only position to the face only position the air does not come out of the 2 center dash vents when I go to a lower fan speed or turn off the A/C the air comes out very strong.
3.) When I turn the steering wheel I hear a little whine it's very minute and it's originating from the gas pedal area, I can feel it around the black rubber housing right next to the gas pedal. Has no affect on steering or driveability, and power steering fluid level is fine.
4.) I hear a slight squeel, almost like a scraping sound while driving coming from the passenger side, when I brake it makes no difference in the level of noise, but the sound is consistent with driving.
Please help! Thanks!
