GPS Antenna Location on Gen 6 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-29-2006, 10:59 AM   #1 (permalink)
hybridamp's Avatar
View hybridamp's Photo Gallery
I know some of you have the service manual for the Gen 6, can you scan the page that shows the stock mounting location in the dash for the GPS antenna?
I'm installing an aftermarket system and might try to utilize the same location as the stock antenna...
Thanks!
hybridamp is offline   Reply With Quote
Old 08-29-2006, 12:43 PM   #2 (permalink)
Don't get mad. Get even.
El Tano's Avatar
View El Tano's Photo Gallery
Man, YOu will wish you never made that question, hahahaha
The location of the antenna, It's underneath the dash, kind of like behind the clock, and in order to do that, It shows that you have to remove the whole dash, heater ducts,speakers.
1. INSTALL NAVIGATION ANTENNA ASSEMBLY
(a) Install the navigation antenna assembly with the 2
screws.
(b) Engage the 3 clamps.
2. INSTALL NO. 2 HEATER TO REGISTER DUCT (for
TMC Made) (See page IP-41)
3. INSTALL NO. 2 HEATER TO REGISTER DUCT (for
TMMK Made) (See page IP-41)
4. INSTALL NO. 3 HEATER TO REGISTER DUCT (for
5. INSTALL NO. 3 HEATER TO REGISTER DUCT (for
6. INSTALL NO. 1 HEATER TO REGISTER DUCT (for
TMC Made) (See page IP-42)
7. INSTALL NO. 1 HEATER TO REGISTER DUCT (for
TMMK Made) (See page IP-42)
8. INSTALL DEFROSTER NOZZLE ASSEMBLY (for TMC
9. INSTALL DEFROSTER NOZZLE ASSEMBLY (for
10. INSTALL SIDE NO. 2 DEFROSTER NOZZLE DUCT
(for TMC Made) (See page IP-42)
11. INSTALL SIDE NO. 2 DEFROSTER NOZZLE DUCT
(for TMMK Made) (See page IP-43)
12. INSTALL SIDE NO. 1 DEFROSTER NOZZLE DUCT
(for TMC Made) (See page IP-43)
Clamp
E129192E01
Clamp
E129192E01
NAVIGATION – NAVIGATION ANTENNA CORD NS–215
NS
13. INSTALL SIDE NO. 1 DEFROSTER NOZZLE DUCT
14. INSTALL INSTRUMENT PANEL SAFETY PAD
ASSEMBLY (for TMC Made) (See page IP-44)
15. INSTALL INSTRUMENT PANEL SAFETY PAD
ASSEMBLY (for TMMK Made) (See page IP-45)
16. INSTALL NO. 1 DEFROSTER NOZZLE GARNISH (See
page IP-48)
17. INSTALL FRONT NO. 2 SPEAKER ASSEMBLY (for LH
Side) (See page AV-156)
18. INSTALL INSTRUMENT PANEL NO. 1 SPEAKER
PANEL SUB-ASSEMBLY (See page IP-48)
19. INSTALL INSTRUMENT PANEL NO. 1 REGISTER
20. INSTALL FRONT PILLAR GARNISH LH (See page IR-
51)
21. INSTALL FRONT NO. 2 SPEAKER ASSEMBLY (for
RH Side)
HINT:
Use the same procedures for the RH side and the LH
side (See page AV-156).
22. INSTALL INSTRUMENT PANEL NO. 2 SPEAKER
PANEL SUB-ASSEMBLY (See page IP-49)
23. INSTALL INSTRUMENT PANEL NO. 3 REGISTER
24. INSTALL FRONT PILLAR GARNISH RH (See page IR-
52)
25. INSTALL NO. 1 CONSOLE BOX INSERT FRONT (for
TMC Made) (See page IP-49)
26. INSTALL NO. 1 CONSOLE BOX INSERT FRONT (for
TMMK Made) (See page IP-50)
27. INSTALL NO. 2 CONSOLE BOX INSERT FRONT (for
TMC Made) (See page IP-50)
28. INSTALL NO. 2 CONSOLE BOX INSERT FRONT (for
29. INSTALL CONSOLE BOX ASSEMBLY (for TMC Made)
(See page IP-51)
30. INSTALL CONSOLE BOX ASSEMBLY (for TMMK
Made) (See page IP-51)
31. INSTALL CONSOLE BOX CARPET (See page IP-51)
32. INSTALL CONSOLE BOX POCKET (See page IP-51)
33. INSTALL NAVIGATION RECEIVER WITH HEATER
CONTROL PANEL ASSEMBLY (See page NS-196)
34. INSTALL INSTRUMENT PANEL NO. 2 REGISTER
ASSEMBLY (See page IP-52)
NS–216 NAVIGATION – NAVIGATION ANTENNA CORD
NS
35. INSTALL UPPER CONSOLE PANEL SUB-ASSEMBLY
(for TMC Made) (See page IP-52)
36. INSTALL UPPER CONSOLE PANEL SUB-ASSEMBLY
(for TMMK Made) (See page IP-52)
37. INSTALL UPPER CONSOLE REAR PANEL SUBASSEMBLY
(for Automatic Transaxle) (See page IP-
53)
38. INSTALL UPPER CONSOLE REAR PANEL SUBASSEMBLY
(for Manual Transaxle) (See page IP-53)
39. INSTALL FLOOR SHIFT POSITION INDICATOR
HOUSING SUB-ASSEMBLY (for Automatic
40. INSTALL UPPER CONSOLE PANEL (for Manual
Transaxle) (See page IP-54)
41. INSTALL NO. 2 INSTRUMENT CLUSTER FINISH
PANEL GARNISH (See page IP-54)
42. INSTALL NO. 1 INSTRUMENT CLUSTER FINISH
PANEL GARNISH (See page IP-55)
43. INSTALL SHIFT LEVER KNOB SUB-ASSEMBLY (for
Automatic Transaxle) (See page IP-55)
44. INSTALL SHIFT LEVER KNOB SUB-ASSEMBLY (for
Manual Transaxle) (See page IP-55)
45. INSTALL LOWER INSTRUMENT PANEL SUBASSEMBLY
(for TMC Made) (See page IP-55)
46. INSTALL LOWER INSTRUMENT PANEL SUBASSEMBLY
(for TMMK Made) (See page IP-56)
47. INSTALL INSTRUMENT PANEL NO. 2 UNDER COVER
SUB-ASSEMBLY (See page IP-56)
48. INSTALL COWL SIDE TRIM SUB-ASSEMBLY RH (See
page IR-55)
49. INSTALL FRONT DOOR SCUFF PLATE RH (See page
IR-55)
50. INSTALL COMBINATION METER ASSEMBLY (for
TMC Made) (See page IP-56)
51. INSTALL COMBINATION METER ASSEMBLY (for
52. INSTALL INSTRUMENT CLUSTER FINISH PANEL
(See page IP-57)
53. INSTALL LOWER INSTRUMENT PANEL FINISH
PANEL (w/o Smart Key System) (See page IP-57)
54. INSTALL LOWER INSTRUMENT PANEL FINISH
PANEL (w/ Smart Key System) (See page IP-57)
55. INSTALL NO. 1 INSTRUMENT PANEL SUBASSEMBLY
(See page IP-57)
NAVIGATION – NAVIGATION ANTENNA CORD NS–217
NS
56. INSTALL TURN SIGNAL SWITCH ASSEMBLY WITH
SPIRAL CABLE SUB-ASSEMBLY
57. ADJUST SPIRAL CABLE SUB-ASSEMBLY (See page
RS-367)
58. INSTALL STEERING COLUMN COVER (for TMC
Made) (See page IP-58)
59. INSTALL STEERING COLUMN COVER (for TMMK
60. INSTALL LOWER INSTRUMENT PANEL FINISH
PANEL LH (for TMC Made) (See page IP-58)
61. INSTALL LOWER INSTRUMENT PANEL FINISH
PANEL LH (for TMMK Made) (See page IP-59)
62. INSTALL COWL SIDE TRIM SUB-ASSEMBLY LH (See
page IR-54)
63. INSTALL FRONT DOOR SCUFF PLATE LH (See page
IR-54)
64. INSTALL STEERING WHEEL ASSEMBLY (See page
SR-51)
65. INSTALL STEERING PAD (See page RS-350)
66. INSTALL LOWER NO. 3 STEERING WHEEL COVER
(See page RS-351)
67. INSTALL LOWER NO. 2 STEERING WHEEL COVER
(See page RS-352)
68. CONNECT CABLE TO NEGATIVE BATTERY
TERMINAL
69. INSPECT STEERING PAD (See page RS-352)
70. INSPECT SRS WARNING LIGHT
(See page RS-32)
GOOD LUCK.....
El Tano is offline   Reply With Quote
Old 08-30-2006, 12:13 PM   #3 (permalink)
hybridamp's Avatar
Woah, Thanks. lol
what is your fav gen camry? 2dcamrystick Camry & Solara Lounge 42 09-17-2006 08:00 AM
Original Wires for Factory Power Antenna... JayMax03 Audio, Video, and Security - Tech 3 06-22-2006 01:02 AM
Gen 4 Door Trigger Location SnakeyeS 3rd & 4th Generation (1992–1996 & 1997–2001) 1 01-05-2006 07:10 AM
CAMRY FAQ ***READ FIRST*** EKam Camry & Solara Lounge 7 07-08-2005 10:05 AM
fuse location for headlight in gen 4.5 camry Tubbyc 3rd & 4th Generation (1992–1996 & 1997–2001) 3 04-20-2004 02:22 AM
