Originally Posted by Super Kaioken
to extend the battery wires.............how would i do that? Could i run the wires along the door sills of the car? sounds pretty complicated.
If i did relocate the battery, it would help a ton to route the intake
While I am new to the Camry scene, I have performed the battery relocation before. I will see if I can help.
For starters, you will need 3 pieces (2 long, 1 short) of 1 guage or 0 guage cable, a marine battery box, probably a battery cutoff switch and you may need to replace a cable on the starter relay, I am not sure about that.
The cable SHOULD be run outside the vehicle and away from fuel and brake lines.
Typically you will get the best deals buying cable from a welding supply company and you will have to install the cable end yourself. Not too hard, just need a propane torch, shrink tubing, cable ends and die electric grease.
A side benefit is if you install the battery on the driver side rear, you will get a weight shift that may improve the handling of the car. This being a counterweight to the driver weight up front.
Let me say this, be sure to ground the battery REALLY well or you will be chasing electrical gremlins FOREVER!
I hope this helps...
