Cutoff pics of my HID retrofit - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-17-2006, 03:25 PM   #16 (permalink)
View taj786's Photo Gallery
Here you go Webb26, the projector housing sticks about an inch and half behind the headlight and about the same in the front. Here are a couple of pics. Hope this helps...
taj786 is offline   Reply With Quote
Old 09-17-2006, 10:46 PM   #17 (permalink)
The Naive Voice of Reason
thapranksta's Avatar
View thapranksta's Photo Gallery
Good work so far. Your beam looks about the same as mine. Believe me, the color looks great hitting cars and objects along the road.
I burned a headlight too. You should probably preheat the oven to 400F instead of 300F. That will stop you from having to put it in the oven more than one time.
Keep us posted.
Old Car: '03 Toyota Camry LE
New Car: '04 Black ES330 (Aftermarket sound/navigation system installed)
Always got something else in mind...
thapranksta is offline   Reply With Quote
Old 09-18-2006, 01:24 AM   #18 (permalink)
Webb26's Avatar
View Webb26's Photo Gallery
Thanks taj786...did you decide to use the OEM grommet to cover that back end up...or will it even fit the way you mounted it? If not...how did you seal up the back end?
Webb26 is offline   Reply With Quote
Old 09-18-2006, 11:01 AM   #19 (permalink)
Thanks for the helpful tips thapranksta, but i scared of burning another headlight...lol. This mod is costing me both of my arms now. Can you send me a few pics of ur headlight assembly and cutoff. Also i want to see what did u use to seal the back of the headlight.
Old 09-18-2006, 11:04 AM   #20 (permalink)
Yeah Webb26, i am planning to use the OEM grommet to cover the back. But i think i am still gonna have some space on the sides, since the top and bottom are gonna be stretched and tight. I am planning to use some electrical tape and put silicon over it make it air tight. I know its a ghetto approach but hey who'll be able to see the inside...lol. But i am still thinking about using some other methods.
Old 09-18-2006, 11:24 AM   #21 (permalink)
Gen 4 XLE v6
jhbhatia's Avatar
View jhbhatia's Photo Gallery
Cut off looks beautiful, color is nice too. Kudos for a great job.
Originally Posted by majorgercko1
Thats leet shit. Nicely done. That last pic- is one of your lights aimed higher than the other or why is it brighter?
I can't believe someone asked this..LOL
The cut off line for projectors should look like below
_ _ _ _ _ / - - - - -
thats the way oem projectors look like.
Desi Toyota Dude Here!!!
jhbhatia is offline   Reply With Quote
Old 09-18-2006, 11:58 AM   #22 (permalink)
Shukriya bhatia bhai. I well deserved a desi compliment.
Old 09-18-2006, 12:14 PM   #23 (permalink)
View majorgercko1's Photo Gallery
He said it himself, they are not even. And i dont know bout you, but my HIDs both look the same when you look from where he took the pic. How can one be brighter than the other. Have not seen a bmw like that. I know what you mean about the cutoff but that still needs fixin which hes workin on.
I dare you to compare...
majorgercko1 is offline   Reply With Quote
Old 09-18-2006, 01:11 PM   #24 (permalink)
Had a question. How the cutoff should look like from a distance. Should it be (left)&(right) _____/------_____/------ or it should be just one _____/----- cutoff where the left and right is overlapping. The beam will look equally bright if they are overlapping one another going like this /\ and forming one cutoff____/-----. Any suggestions majorgercko1
Old 09-18-2006, 02:20 PM   #25 (permalink)
Gen 4 XLE v6
jhbhatia's Avatar
The latter.
majorgercko1: I wasn't minimizing your efforts. I was just point out something people with OEM HID's know...the pattern is single _ _ _ _ / - - - - The right is elevated for LHD Cars; if you happen to drive in asia where its RHD, the pattern is - - - - \ _ _ _ _
I'd recommend you to check out some HID forums to learn on beam patterns on retro-fitted projectors.
Requesting HID pics without retrofit... jaep0913 5th & 6th Generation (2002-2006 & 2007-2011) 26 11-13-2006 06:03 PM
HID Group Buy jtrovato 2nd Generation (2005+) 15 06-05-2006 09:44 AM
Performance World March 10-2006 (90 pics within) g1zm0 General Discussion 0 03-11-2006 11:51 AM
Pics Of My Car With Rims Rapeacivic Camry & Solara Lounge 45 05-12-2004 08:47 AM
pics reply camry dragger Camry & Solara Lounge 1 03-09-2003 12:21 AM
