Yah, it just happened to me again the other day.
I'm almost positve that it is related to miles between oil changes. At least that is what it says in the manual, if you don't do anything about it it will eventually become solid. But its only happened to me twice and I've changed my oil more than twice.
but to clear... with key in off position and odometer in overall milage mode (not trip a or b) hold odometer reset buttom down while turning key into on position (not far enough to start engine) the odometer will show bars in the position of the numbers and slowly count down to no bars and clear the message then the light will go away.
it hould tell you in the maunal, I just did it 2 weeks ago and that is where I got the procedure.
-sqjr
