Okay, first of all, I have a five OEM 2005-2006 SEV6 17" Rims for the Camry Gen 5.5
I once knew what tired size was recommended, but I lately forgot the number now since I've finally mustered myself to get off my ass and buy some shoes for these gunmetal babies.
So, what size would be the correct one for these rims? They're 17"x7.5 rims. I believe it was a 225/50 17 tires? Or is there a different size?
*Hope you don't mind but i'd like to add two more questions since they are somewhat relevant.
If you get new tires which are bigger then the stock ones is there anyway to recalibrate the speedometer, and will you lose any performance due to the increase in size?
They're 17x7. Stock size is 215/55-17.
If you plus size correctly, there should not be any need to recalibrate because the circumference should be the same.
There are many more variables to determine if a wheel will cost performance than diameter.
Thanks for the replies but I was asking about a larger circumference size, sorry for not being clear in my post.
You're effectively making the final drive taller. Which means that you will lose some acceleration. But, given the same weight and friction, a taller wheel and tire will give you better gas mileage on the highway.
Use the following calculator to figure out what plus-sizes will not affect your speedo reading. Basically, select a tire size which will have nearly the same circumfrence.
