Satellite radio noise from the Aux port.. 07 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-29-2006, 09:45 AM   #1 (permalink)
View dirtdiggler's Photo Gallery
Gen6 Satellite radio noise from the Aux port.. 07 Camry
Hello All,
probably should post this on the Audio site, but its Camry related.. I wonder if anyone has come across and fixed the problem. Here's the problem : I have a Sirius S50 satellite radio plugged into the Camry's auxillary port.. Everything is great until the lights are on and then a whizzing sound is apparent and annoying.. Now I was able to quiet the noise with PAC SN-1 / 3.5mm inline noise filter from Crutchfield, but it also filters out the bass and blands it down.. I think that the 12V port and the auxillary port are too close to each other causing the noise, but that kind of cancels my theory because my 07 FJ has the some distance with the power and auxillary port. Might be that the S50 Sirius is more sensitive. I am thinking if there is a good shielded 3.5mm auxillary cable available ? My plan of remedy tonight is to plug the S50 power cord to the second 12V on the console and see if that cures the problem.
thanks in advance
dirt diggler
91 Previa w/275k
07 Mercedes C230 Sport
07 FJ Cruiser
92 Lexus SC400 w/84k
97 Prelude w/86k
dirtdiggler is offline   Reply With Quote
Old 11-29-2006, 11:48 AM   #2 (permalink)
07 Camry SE V6
wilfredcruz's Avatar
View wilfredcruz's Photo Gallery
Hello All,
thanks in advance
dirt diggler
did the same... same noise from the console outlet.
filter fix it. i also fixed it buying the toyota XM kit
2007 Camry SE V6 /Leather/sunroof/JBL
Added: XM Sat Radio (Toyota), 18in Wheels (Rial), 3M Tints (35%), LED Interior lights. TRD Lowering Springs
Removed: Camry Se Badges
wilfredcruz is offline   Reply With Quote
Old 11-29-2006, 12:25 PM   #3 (permalink)
View Regds55's Photo Gallery
I have Sirius Starmate 4,had same noise. Filter from Crutchfield fixed noise and have not noticed drop in bass or volume.I'm using front power and aux. ports.
Regds55 is offline   Reply With Quote
Old 11-29-2006, 12:31 PM   #4 (permalink)
View majorgercko1's Photo Gallery
Have you heard of the Auxies. They are little people that can be found on the aux ports on many stereos. They can cause many problems They originate from Japan. That probably means your car was built in japan. There is a cure. You must soak the entire system into chlorine. It will kill them.
I dare you to compare...
majorgercko1 is offline   Reply With Quote
Old 11-29-2006, 01:44 PM   #5 (permalink)
View Sgt Tip's Photo Gallery
Same Radio Noise
I have a 07 SE V6 and had the same problem with my xm roady xt. Went the Crutchfield filter route also it worked for about a hour then the noise returned finally went the factory route $238. went to a auto radio installer ( not Bestbuy or Circuit city ) paid a $150. and the radio is great. The radio shop did say the JBL Premium radio made by Pioneer is very expensive way over the $1000. option price it is. You would think for a grand the XM would be functioning at delivery.The answer I got from sales was it gives the owner a choice between XM or Serious. Good Luck
Sgt Tip is offline   Reply With Quote
Old 11-30-2006, 12:51 PM   #6 (permalink)
Just remembered, turning off FM transmitter(on by default) made a big differance in sound quality.
Old 12-01-2006, 05:39 AM   #7 (permalink)
Gen6 Satellite radio noise from the Aux port.. 07 Camry - SOLVED-
-SOLVED-
Thanks to all that replied with great suggestion.. I purchased a Scosche In-Line power lead noise suppressor with RCA inputs. Part number ES034. Purchased at WalMart for 14.00 bucks and bought female to female connection from radio shack to connect RCA to 3.5 plugs to the Camry's auxillary plug and my Sirius S50. The outcome is great. I have Bass and Stereo.. I checked by unlugging and using the Fm modulator I was using before. No problem.. So thanks to everyone and hope this helps for future users. I have pics, but I need to clean and hide the install. I will take pics of the Scosche suppressor. The Camry has knock-out on the passengers side cubby hole to access the console pocket. there is also a gap between the console and side pocket to fish the antenna and hide the wires under the passenger carpet. - my next mode is to shorten the shifter shaft and re-thread and install a new shofter knob.
dirt diggler
91 Previa w/275k
07 FJ Cruiser
97 Prelude w/86k
Old 06-10-2011, 01:34 PM   #8 (permalink)
View AmandaCraig's Photo Gallery
Just in case someone still has problems here's a link to an article on this issue and a TSB:
bwave.ca/2011/06/10/toyotas-whining-noise-from-the-aux-port
AmandaCraig is offline   Reply With Quote
History of the Toyota Camry Ratko Camry & Solara Lounge 54 01-13-2012 08:42 PM
Installing a factory satellite radio in a Highlander brucep Toyota Highlander Hybrid 9 08-20-2007 09:24 PM
Overall Comparison: Toyota Camry XLE V6 v.s. Pontiac Grand P CamryLeb Camry & Solara Lounge 25 08-13-2007 10:55 PM
Satellite radio noise from the Aux port.. 07 Camry dirtdiggler 5th & 6th Generation (2002-2006 & 2007-2011) 2 11-29-2006 09:30 PM
my Camry 03 makes loud rattle noise! please help poraminna 5th & 6th Generation (2002-2006 & 2007-2011) 7 02-23-2005 05:35 PM
