Gen 5 Camry Transmission Fluid Change Intervals? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-30-2006, 03:37 PM   #1 (permalink)
View 1200mk's Photo Gallery
I have about 50k mi. I think I am due for a transmission oil change.
Am I late?
And how much does it usually cost?
1200mk is offline   Reply With Quote
Old 11-30-2006, 10:22 PM   #2 (permalink)
View sundarpn's Photo Gallery
i have 50 K miles on my 02 XLE too... that I got about 3 months ago.
Not sure what the interval is to get the fluid changed.
sundarpn is offline   Reply With Quote
Old 12-02-2006, 05:46 PM   #3 (permalink)
i read that if the oil is pink, it's still good. If it's brown it is time to change.
There isn't a filter on the camry is there?
Old 12-02-2006, 11:24 PM   #4 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $400224
View BlackCamSe's Photo Gallery
there is a filter in the trany, if i were you i would get the fluid changer right away, if u wait any longer and change the fluid later down the line you will actually do more harm then good.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is online now   Reply With Quote
Old 12-11-2006, 03:20 PM   #5 (permalink)
FLIP'N THE G-5 WHIP
RICO8458's Avatar
View RICO8458's Photo Gallery
why more harm than good? what happens?
Got the 50 on my jock cause my G-5 is so Hot...
2005=5.5 2AZ-FE, 2.4L DOHC 16-Value VVT-i, 4CYL, 160hp
RICO8458 is offline   Reply With Quote
Old 12-11-2006, 03:28 PM   #6 (permalink)
The Naive Voice of Reason
thapranksta's Avatar
View thapranksta's Photo Gallery
The dealer told me that the radiator and transmission should be flushed at around 60k. Was this incorrect information?
Old Car: '03 Toyota Camry LE
New Car: '04 Black ES330 (Aftermarket sound/navigation system installed)
Always got something else in mind...
thapranksta is offline   Reply With Quote
Old 12-11-2006, 04:03 PM   #7 (permalink)
View shimp999's Photo Gallery
My Haynes manual says every 50,000 miles do a drain and refill. So no it shouldn't be "too late". When people say "more harm then good" it usually refers to those who have never serviced their transmission fluid with tons of miles on their car (like 100k+ or something). Usually by that point all the gunk in the fluid is whats keeping your transmission together.
I do a drain and refill every 30,000 miles. Its fairly easy to do. As for cost, I just got my gf's Corolla flushed for $80 bucks. I called my dealer and they gave me a quote of ~$60 to do a drain and refill for my 2004 Camry.
If you do it yourself, I think the Toyota ATF Type T-IV fluid is like $5 bucks a quart from the dealer. Tire Kingdom mechanic tells me the Valvoline ATF fluid is a Type T-IV and its fine for my Camry, but my Haynes manual says exactly Toyota ATF. So I go with the Toyota stuff
shimp999 is offline   Reply With Quote
Old 12-11-2006, 04:09 PM   #8 (permalink)
So am I fine at 60k?
Old 12-11-2006, 04:16 PM   #9 (permalink)
Yes, you're fine. Check your fluid level on your transmission after you get back from a trip to the grocery store or something to make sure its warm. Also the color should be a light red/kinda pink. If its a real dark red or brown it should be changed. Also, if it smells burnt.
Old 12-18-2006, 08:51 PM   #10 (permalink)
View marc780's Photo Gallery
I say dont wait til it turns brown or otherwise changes color, just change it and not be a cheapskate or something.
change your atf or change your transmission at 150k, your choice.
Old 12-19-2006, 12:07 PM   #11 (permalink)
Registered User
View qprint's Photo Gallery
when checking the trans dipstick, why is one side of the stick have a different reading than the other side ? And should you follow the lower reading or the higher one ?
qprint is offline   Reply With Quote
Old 12-19-2006, 12:12 PM   #12 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $172825
View JSM1284's Photo Gallery
Every 30k, Do not do anything to it if it has gone over 60k without a trans service being performed ever.
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Old 12-19-2006, 12:27 PM   #13 (permalink)
2002 Camry
ToyotaToday's Avatar
View ToyotaToday's Photo Gallery
Actually the GEN5 is very easy to change. You can do it yourself. But read the proper procedures in a manual. The engine/tranny has to be warm, running, and in Park before you check the tranny fluid level. Never over or under fill. You don't want to damage the tranny.
There's a drain plug like the drain plug for your oil.
2006 4Runner Limited
ToyotaToday is offline   Reply With Quote
Old 12-19-2006, 03:39 PM   #14 (permalink)
View MinMet's Photo Gallery
I looked at the manufacture's service manual. Couldn't find any description about the ATF change procedures. Any body care to describe it. Also, what's the capacity for drain and fill? Is there a specific filler balt or just through the dip hole? Thanks!
Min
MinMet is offline   Reply With Quote
Old 12-19-2006, 04:10 PM   #15 (permalink)
Webb26's Avatar
View Webb26's Photo Gallery
Just out of curiousity...since i have never changed tranny fluid before....is there any difference between auto tranny and manual tranny as far as procedures?
Webb26 is offline   Reply With Quote
Should I Skip The Camry Alltogether?!?! hikix 5th & 6th Generation (2002-2006 & 2007-2011) 104 05-30-2008 12:33 AM
Transmission fluid change question orbital Previa Forum 2 12-19-2006 02:18 PM
Transmission fluid change question orbital Previa Forum 0 10-04-2006 12:26 PM
1MZ Transmission fluid lines: 2001 camry cowan55 3rd & 4th Generation (1992–1996 & 1997–2001) 1 09-10-2006 04:15 PM
Transmission Fluid Change mike1117 General Discussion 8 04-07-2005 07:28 PM
