Will 245/45/18 fit without rubbing??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-30-2006, 11:04 PM   #1 (permalink)
07 Camry Owner
View madcorolla's Photo Gallery
Hello, I just purchase some 18's for my new 07 Camry CE. Does anyone know if 245/45/18 will fit without rubbing? Please let me know, thanks
madcorolla is offline   Reply With Quote
Old 12-01-2006, 02:23 AM   #2 (permalink)
View TRDGen5.5camry's Photo Gallery
what is that rim offset??? and how wide is that rim???
TRDGen5.5camry is offline   Reply With Quote
Old 12-01-2006, 04:12 AM   #3 (permalink)
07 Camry Owner
They are 18x7.5 +45mm \
Old 12-01-2006, 08:51 AM   #4 (permalink)
Brandon402's Avatar
View Brandon402's Photo Gallery
Is the car dropped at all?
Brandon402 is offline   Reply With Quote
Old 12-01-2006, 08:59 AM   #5 (permalink)
07 Camry Owner
No
Old 12-01-2006, 10:20 AM   #6 (permalink)
Regg07Camry
View Regg07CamryV6LE's Photo Gallery
that should clear with no problem
Regg07CamryV6LE is offline   Reply With Quote
Old 12-01-2006, 12:29 PM   #7 (permalink)
Don't get mad. Get even.
El Tano's Avatar
View El Tano's Photo Gallery
Even if you lower the car it will be not problem at all. With a 7.5 wheel I "think" that you can go up to +40 offset without rubbing and it will fill the gap very nicely. I have 18x8 +42 offset with 235/45 18 and 1.75 springs and I can put my fingers in between the wheel and the fenders. Next rims are gonna be +40 for me..
If you are thinking lowering the car I would recommend that you lower the car first and latter get the right size and offset to fit your needs....
Good luck
El Tano is offline   Reply With Quote
Old 12-01-2006, 12:46 PM   #8 (permalink)
08 Voodoo Blue FJ Cruiser
View hotboi's Photo Gallery
Gen6
Sorry not to steal you post but I posted this a couple of weeks before in the Hybrid section but didn't get any response....
I was wondering if these would fit on my 07 TCH:
wheels:
http://www.discounttiredirect.com/di...4.3&vid=010329
tires:
http://www.discounttiredirect.com/di...29&rd=18&ar=45
No the car is not lower. Currently everything is stock for now...but these are the wheels i'm looking to purchase.
Any feedback would be greatly appreciated.
Thanks,
Hotboi
hotboi is offline   Reply With Quote
Old 12-01-2006, 12:54 PM   #9 (permalink)
07 Camry Owner
Originally Posted by SuperGoop
245 wide tires should ideally be mounted on 8" wide rims. 7.5" wide rims may be a bit too narrow for your tires.
So are you saying that the tire will come off or be unsafe to drive? Please explain, thanks.
Old 12-01-2006, 01:09 PM   #10 (permalink)
Under Reconstruction
Epsilon's Avatar
View Epsilon's Photo Gallery
wheels:
tires:
Thanks,
Hotboi
If possible, I would recommend going with a lower offset allowing the wheels to sit more flush with the fenders.
Epsilon is offline   Reply With Quote
Old 12-01-2006, 01:09 PM   #11 (permalink)
07 Camry Owner
bump
Old 12-01-2006, 01:18 PM   #12 (permalink)
Epsilon's Avatar
You can mount a 245 wide tire on a 7.5 wide wheel, but it's optimal to mount it on at least a 8 wide wheel allowing for best tire performance and prevents possibilities of wheel or tire failures.
Old 12-01-2006, 02:19 PM   #13 (permalink)
Question
Originally Posted By Epsilon
EpsilonQuote:
wheels:
http://www.discounttiredirect.com/direct/findWheelDetail.do?mk=&yr=2007&wd=18&pc=68661&rw=7 .5&bp=5-114.3&vid=010329
tires:
http://www.discounttiredirect.com/direct/findTireDetail.do?mk=&yr=2007&cs=225&pc=33524&vid= 010329&rd=18&ar=45
Thanks,
Hotboi
Well the offset is +45, correct? So what do you recommend than? I thought +45 is what you should go with...guess I'm wron or did I read it wrong from the website....
Sorry, I'm a noobie
Old 12-01-2006, 02:24 PM   #14 (permalink)
07 Camry Owner
So a 235 series tire would be better with less chance of failure?
Old 12-01-2006, 02:48 PM   #15 (permalink)
Epsilon's Avatar
Sorry, I'm a noobie
Your current offset is +45, but then again you are currently running on wheels that are 6.5" wide. Since you are increasing the width to 7.5", I would see if they have the wheels in a +35, +40, or +42.
Wheels that will fit! Dseldown 89-95 Toyota Pickup/Hilux 3 02-07-2006 05:51 PM
blinkers dont fit!! Mayne Event Camry & Solara Lounge 6 10-14-2005 07:11 PM
Would a camry motor fit a sienna without any mods? tousi Camry & Solara Lounge 22 10-04-2005 02:30 PM
Witch engines fit the Sienna? tousi 1st Generation (1998-2003) 1 09-26-2005 11:14 AM
HELP! will these rimz fit pk_kk Camry & Solara Lounge 5 06-06-2005 03:42 PM
