for several months i had my camry, it started making a hissing or kind of like a whistling sound from the engine. Ive researched on this forum but couldnt get a straight answer. Is this normal for my car make this noise ? i think some of you guys here has experienced the same thing as i am. thanks in advance
mine does it when i rev it, like it goes pssh and then revs, the 2AZ-FE has several engine noises that are normal, ticking, valve lifter+timing chain slapping around. How often do u here this noise, what kind of driving conditions, engine rpm,....etc.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
i think i hear this noise mostly from the morning when i first get out of garage and start gasing it. i normally dont go above 3k rpm so... im hoping its nothing =]
So was it nothing? I use my 08 camry 4cyl as a daily driver and I've racked 14k on it. I noticed that on the driver's rear side, I hear a loud, constant hissing noise.. kinda sounds like air leaking out at a constant rate, but Ive checked my tires and they are all inflated properly.
I am not here to judge how you post, I don't mind, just unlikely that reviving an old thread which is only somewhat close helps to get started - therefore, I referenced a thread which might help how you can get an answers from the experts here (not me)....
Hey! I'm a noob, but I used the search and found this. Take that, other users. Don't throw your stones at me....
Anyways, just a couple of days ago I noticed a constant hissing noise coming from under my car. It's located mainly around the rear driver side, but can also be heard distinctly from the passenger side too. It sounds just like air leaking out of my tires, but my tires are fine, and the sound only occurs when the car is on. I'm kind of assuming it is something with my exhaust line... ??
Any help would be greatly appreciated it. I'll also search around for a while.
Zombie thread, back from the dead, will eat your brains
I'm sorry, I should have been more specific. This problem is constant from the moment that I cut on my car to the moment I shut it off. It can be in park in the parking lot and the sound is still occurring. It also does not get any louder when I hit the gas. It just stays the same all the time. It's a constant noise that occurs at all times when the car is cut on and does not seem to change intensity. Thanks again!!
