02 LE Front Door Speakers Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-13-2006, 10:15 AM   #1 (permalink)
View wcarty's Photo Gallery
I have already taken my 02 LE to best buy and they atempted to switch out the factor front door speakers with Alpine speakers, Even after ordering a special spacer ring they said that speaker would still make contact with the window.
Does anyone know if I could use these insted, and would these still require a custome MDF bracket?
Alpine Type-R SPR-17LP
6-1/2" 2-way
wcarty is offline   Reply With Quote
Old 12-13-2006, 06:58 PM   #2 (permalink)
Dominican Republic
Dj-torn's Avatar
View Dj-torn's Photo Gallery
click my picture below and go to " front speaker project". to see how to over come your problem.
Stock 2002 Camry LE: 2AZ-FE: VVT-i
Dj-torn is offline   Reply With Quote
Old 12-13-2006, 07:25 PM   #3 (permalink)
View nimo's Photo Gallery
I got some Type S in there using 1/2" MDF adapter. I just used the stock speaker brackets as a template. I mounted crossover behind the adapter while removing the crossover's top cover. From the crutchfield website it says to use 3" mounting dept speakers.
nimo is offline   Reply With Quote
Old 12-13-2006, 10:27 PM   #4 (permalink)
The Naive Voice of Reason
thapranksta's Avatar
View thapranksta's Photo Gallery
I just put some 6 1/2'' speakers in the front doors of my car. I was saving this for later after I saw how well they lasted but I used these speaker adapters and so far no problems.........pure plug and play. These are for a 4runner but the front speaker bracket for the 4runner is the exact same shape as the front speaker bracket for the Camry so these adapters work fine (so far). Being that 6 1/2'' speakers have lower mounting depth than 6x9''s, this should solve your problem.
http://www.cardomain.com/item/SCOSAT69
Old Car: '03 Toyota Camry LE
New Car: '04 Black ES330 (Aftermarket sound/navigation system installed)
Always got something else in mind...
thapranksta is offline   Reply With Quote
92 le Wiper problem (advice needed) mikerowesoft 3rd & 4th Generation (1992–1996 & 1997–2001) 6 12-12-2007 09:32 AM
Whiteline; Superpro and Dobinson Group Sale ...PART II raptorracing Supporting Vendor Sales 93 05-02-2007 05:02 AM
List your Gen5 Problems mtnet2000 5th & 6th Generation (2002-2006 & 2007-2011) 61 10-15-2006 07:18 PM
Stock Navi in 02 LE Without? rikus 5th & 6th Generation (2002-2006 & 2007-2011) 5 07-12-2003 11:50 AM
