Originally Posted by mrxbobert
Thanks for the reply! I actually do not have the cut outs. THe cut out i was referring to was the indentation on a molded bumper that indicates where the fogs should go. I found a shop who can do some sort of mounting bracket from the metal bumper.
as long as they can make it look good, you'll probably save quite a bit of money that way. either way, i still think you are prewired for fogs, because of the fuses already being in place.
The driver panel you are referring to...is that the door near the left knee below the steering wheel? I'm not sure if you mean they are behind the fuses that I saw or not. Thanks for your help (...on multiplie occasions..i took your advice on the LED lighting and website to buy it from  )
yup... the panel near the left knee below the steering wheel is what i'm referring to. when you take that panel off, you see the fuse box... on the reverse side of that fuse box are the relays. these are not visible from that panel, nor are they easily accessible. you can try reaching under the dash panels to put the relay in, but the last time i did that, i found it very very difficult. it is far easier just to take the dash panel trim off and install the relay.
