2007 Sport Shift? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-27-2006, 11:27 AM   #1 (permalink)
2007 Black XLE V6 Camry
View smilepak's Photo Gallery
2007 Sport Shift?
Question:...
On the SE/XLE/etc in the 2007 Camry model, when you are in "D" mode and on the freeway driving let say 80mph...that should put it in 6th gear...
Why the heck when you move it over to "S", it auto default to 4th gear?!, Should it default to the gear it is currently on? Man, I moved it over to "S" and my RPM went wack cause it defaulted down to 4th gear, so the car forced it self down to 4th gear while cruising at 80mph...
Is that normal?
First time I have a car with a sport shift...
smilepak is offline   Reply With Quote
Old 12-27-2006, 11:46 AM   #2 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $172825
View JSM1284's Photo Gallery
Its suppose to default to 4th. Just move it over, then paddle it up into 6th really fast
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Old 12-27-2006, 01:29 PM   #3 (permalink)
View lonewolf1187's Photo Gallery
that automatic shift to 4th is the only weird option for the camry imo. some cars i've driven like the 06 maxima has a sport shifter that shifts to the gear your currently in.
lonewolf1187 is offline   Reply With Quote
Old 12-27-2006, 01:39 PM   #4 (permalink)
I think it is silly too. It should shift into the gear you are currently on so you have the option to shift up or down from that point.
Old 12-27-2006, 01:42 PM   #5 (permalink)
View tagpats's Photo Gallery
S mode
i believe the reason for the default to 4th is so you can quickly drop into a lower passing gear when at higher speeds. some people just hit the gas harder in automatic to get the tranny to drop into a lower gear for a quick burst of acceleration, others like to switch it to s mode to more quickly drop gears for passing.
if you use the manual in other circumstances, you will find that the car automatically shifts up to the number you have it set in. so if you set it to 3, the car will shift from 1st to 2nd to 3rd automatically, but you will have to manually shift up from that point.
tagpats is offline   Reply With Quote
Old 12-27-2006, 01:43 PM   #6 (permalink)
666
View 666's Photo Gallery
i kind of like it because its closer to 3rd and my rpms are high enough that i can accelerate faster to pass cars
2007 SE V6
666 is offline   Reply With Quote
Old 12-27-2006, 04:07 PM   #7 (permalink)
View onsknht's Photo Gallery
It will default to 5th and 6th, you just need to be going faster when shifting to S... I would rather it go to a gear less than 4th, such as doing 30-40 MPH, it would be better suited to defaulting to 2nd gear.
2GR-FE
onsknht is offline   Reply With Quote
Old 12-27-2006, 04:28 PM   #8 (permalink)
View moeharri's Photo Gallery
I believe this is the only way to turn overdrive off, and is the reason that it goes to a max of 4th gear (since gears 5 and 6 are overdrives). On the Gen 5 Camry, it had an O/D Off button, but the Gen 6's do not.
2007 LE V6 Magnetic Gray, JBL, Moonroof, Toyota Leather Shift Knob, Toyota All Weather Mats, SE Grille, Wheelskins cover
2007 Odyssey EX (traded in 05 XLE I4 Lunar Mist)
moeharri is offline   Reply With Quote
Old 12-27-2006, 07:09 PM   #9 (permalink)
Posting via Handheld
wireless's Avatar
View wireless's Photo Gallery
I like it b/c on the highway it is useful as the first step in engine braking.
This is where you insert your signature
wireless is offline   Reply With Quote
Old 12-27-2006, 07:54 PM   #10 (permalink)
Yea, but when you are travelling at highspeed, it auto jump on the RPM..which is bad for the engine, no? Especially when it could potentially knock the RPM in the red zone...usually occur when you accidently tap over to "S" mode while driving let say over 80mph?
Old 12-27-2006, 09:02 PM   #11 (permalink)
Mistabullet's Avatar
View Mistabullet's Photo Gallery
No it won't go into the red zone. It will start out at 5 if it feels like the speed is too much for 4th gear. And there isn't anything wrong with taking the engine into the upper RPM's as long as you don't keep it there for long.
Mistabullet is offline   Reply With Quote
2007 SE Sport Pedals missing pjp 5th & 6th Generation (2002-2006 & 2007-2011) 29 11-18-2006 02:29 PM
Lexus Announces Pricing on 2007 ES 350 Luxury Sport Sedan Avalonman Toyota News 3 05-05-2006 04:25 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 01:49 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 0 03-29-2006 12:01 PM
TRD Sport VS. TRD OFf Road Supension Answer GTCOMA 2nd Generation (2005+) 0 03-15-2005 10:28 AM
