Simple Rims Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-27-2006, 04:23 PM   #1 (permalink)
2007 Black XLE V6 Camry
View smilepak's Photo Gallery
Hi,
I never had the need to replace my rim before so this is a simple question...
On 2007 Camry XLE V6 it comes standard with 16" rims (P215/60R16). With that, let say if I am interested in an 18" rim, what tire size would I go for? How do I determine what tire size to use?
P215/60R16? If I get a larger tires, I can only increase P215 and not 60R right?
When buying a rim, I see 18x8, 18x7.5 etc. Will that affect the tire size too?
I am looking at www.tirerack.com and it said I need to purchase the TPMS Sensor (which cost an arm and a leg for) because the XLE comes with tire pressuring detection system...
smilepak is offline   Reply With Quote
Old 12-27-2006, 04:47 PM   #2 (permalink)
Under Reconstruction
Epsilon's Avatar
View Epsilon's Photo Gallery
The tire size should depend on the width of the wheels and how much comfort you want. Currently your tires are 215/60/18/.
215 - width of the tires
60 - aspect ratio
18 - size of the tires
When choosing tires, you should keep in mind to stay somewhat close to your oem tire diameter.
Epsilon is offline   Reply With Quote
Old 12-27-2006, 05:01 PM   #3 (permalink)
HID/Retrofit Expert
white3ch0c0late's Avatar
iTrader Score: 7 reviews
View white3ch0c0late's Photo Gallery
Use a tire calculator at 1010tires.com ...just plug in your current tire, and up to 3 different other sizes, and it'll tell you the differences. You will want to stay as close to your stock diameter, like Epsilon said.
2009 Audi TT 2.0T --- THE BEAST!
2002 LE 4Cyl --- Gone, but not forgotten. 06/28/09
Glaring blue HID bulbs are NOT classy, and don't make your car look nice, no matter what that kid in the Civic told you.
white3ch0c0late is offline   Reply With Quote
Old 12-27-2006, 06:33 PM   #4 (permalink)
Don't get mad. Get even.
El Tano's Avatar
View El Tano's Photo Gallery
235/45 18 or 245/ 45 18 are the closest to original Overall wheel diameter size...
El Tano is offline   Reply With Quote
Old 12-28-2006, 03:47 PM   #5 (permalink)
Epsilon's Avatar
On the wheels you are buying, what's the wheel width?
Old 12-29-2006, 11:20 AM   #6 (permalink)
I do all my own stunts
View 07XLE's Photo Gallery
Also your current wheels have the TPMS sensors, you do not need to purchse additional sensors unless you intend on using the stock wheels for say winter use, otherwise you can simply move the TPMS sensors to the new wheels, it's part of the valve assambly.
'07 Camry XLE V6, Titanium Silver, Moonroof, Spoiler, JBL Audio, Tint, Car Seat
07XLE is offline   Reply With Quote
Old 12-30-2006, 01:35 AM   #7 (permalink)
View ArtA's Photo Gallery
"The tire size should depend on the width of the wheels and how much comfort you want."
if we are looking for comfort or less noise is there a better # of the tires or rim we should be looking at,. thx.
ArtA is offline   Reply With Quote
Old 12-30-2006, 03:16 AM   #8 (permalink)
touringcamry's Avatar
Gameroom cash: $510725
If you want comfort and less noise, stick with the tires you currently have. Increasing the size of the wheels and reducing the sidewall generally makes the ride stiffer.
Lower profile tires are generally, not always, performance tires which emphasize performance. Longetivity and noise take a back seat.
2007 Camry 2.4L 5M
Old 12-30-2006, 11:28 AM   #9 (permalink)
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
For detailed information: http://www.rims-n-tires.com/rt_specs.jsp
215/60/18
If you increase the 60 profile, less noise and more comfort will occur.
But by increasing the 60 profile, you have to decrease the 18" size to 17" to keep original overall diameter.
By decreasing wheel size to 17", you lose a bit of handling due to the taller sidewall, which is the increased 60 profile.
If you increase 215, it'll increase handling, due to more grip, but decrease fuel economy.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
Question about my rims (with Pics) electriceel 1st Generation (1995.5–2004) 5 11-12-2006 08:00 AM
Noobish question bout hub and rims Ultima Camry & Solara Lounge 7 10-14-2005 04:04 AM
Question about 18x8 rims for 1999 camry le 4cyl. trdcamrygracia 3rd & 4th Generation (1992–1996 & 1997–2001) 6 02-13-2005 01:21 AM
Question about 18" rims for a gen 3 Cam KILRCAM 3rd & 4th Generation (1992–1996 & 1997–2001) 12 02-12-2005 04:39 PM
ae92 rims question karma Archived Corolla threads 8 03-12-2003 03:16 PM
