Amp Install Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-29-2006, 02:49 PM   #1 (permalink)
160swiftly's Avatar
View 160swiftly's Photo Gallery
Gen6 Amp Install Problem
I've got my car all apart to run the wires for my amp. I got instructions from the local sterio shop on where the remote wire goes to the ignition power wire, but when I took it apart it didn't look the same as in the pic. Thats because the pic was from a '97 not an '07 . Now I need to run the remote wire to my amp and don't know which wire to tap into.
I've kept the factory deck. Please help.
Thanks,
Amo
160swiftly is offline   Reply With Quote
Old 12-31-2006, 08:50 AM   #2 (permalink)
Posting via Handheld
wireless's Avatar
View wireless's Photo Gallery
Thanks,
Amo
The remote wire is simply a 'swtich' so the ignition triggers the amp to power up and it doesn't stay on all the time. Any switched source in the fuse box will work. How about the radio fuse? Tap into the circuit downlink from the source (the side of the fuse that has the wire going out to the radio).
BTW: On the wiring harness for your head unit, the ignition wire is usually yellow.
This is where you insert your signature
wireless is offline   Reply With Quote
Old 12-31-2006, 01:44 PM   #3 (permalink)
160swiftly's Avatar
Thanks, problem solved. I used a piggyback fuse link.
Should I Skip The Camry Alltogether?!?! hikix 5th & 6th Generation (2002-2006 & 2007-2011) 104 05-30-2008 12:33 AM
1992 Lexus Es300 ABS Problem Anovice Camry & Solara Lounge 6 10-13-2006 08:32 PM
2006 Chart: Recall woes grip Toyota fargoal Toyota News 30 07-25-2006 12:14 PM
Amp problem?? blacktaco Audio, Video, and Security - Tech 2 06-20-2006 02:07 PM
