Parking brake - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-31-2006, 06:55 PM   #1 (permalink)
touringcamry's Avatar
Gameroom cash: $510725
Parking brake
How many clicks does it take to set the parking brake on your 07 Camry?
My 00 Camry needed about 5 and the car wouldn't budge. My 07 takes 10-11 clicks and quite a bit more force when setting the brake to hold the car on the same incline where I parked my 00. My 00 had disc/drum brake and my understanding is that 07s have a disc/disc setup. Is this what accounts for the difference?
2007 Camry 2.4L 5M
Old 01-12-2007, 11:51 PM   #2 (permalink)
TTT
No one knows?
I was stopped on a gentle hill today and I put my car in neutral and pulled the parking brake all the way up. When I let go of the brake my car started rolling backwards down the hill.
Over a distance of about 150 yards, the hill probably went up about 10-15 ft, so it's not that steep.
Is this typical of a 2007 Camry with 4 wheel disc brake or does this need adjustment?
2007 Camry 2.4L 5M
Old 01-12-2007, 11:59 PM   #3 (permalink)
View tom5681's Photo Gallery
I have a foot pedal parking brake. It takes a couple of clicks but I have never counted. I think it doesn't matter so long as you can stop the car from rolling down a hill (even if you have to put the brake to it's max.).
I saw the parking brake under my cupholders when I was installing my interior leds. It looks like it's adjustable to some degree.
Hope that helps.
'07 SE I4 Automatic: Cobra LED shifter | Tire cap LEDs <-stolen | Shaved Emblems | "Ram-Air"Hood
tom5681 is offline   Reply With Quote
Old 01-13-2007, 12:15 AM   #4 (permalink)
Pedal brake? I thought those are only on the XLE?
2007 Camry 2.4L 5M
Old 01-13-2007, 12:39 AM   #5 (permalink)
View astrokat's Photo Gallery
I had the pedal break on and I had no problem backing out of my drive way. When I went to go forward I didn't budge. Thats when I said "oops" ... and then I said "wtf? .. how did i back out of my driveway"
astrokat is offline   Reply With Quote
Old 01-13-2007, 01:52 AM   #6 (permalink)
I forgot to mention that I have a parking brake lever which migh have a slightly different setup compared to the pedal brake.
2007 Camry 2.4L 5M
Old 01-13-2007, 02:42 AM   #7 (permalink)
Parking breaks do wear out. Usually when I have break service, the parking break servive is included. How many miles do you have?
Old 01-13-2007, 08:15 AM   #8 (permalink)
My car has 385 miles on it
I think my parking brake is out of adjust
2007 Camry 2.4L 5M
Old 01-13-2007, 09:11 AM   #9 (permalink)
The Biggest comment Whore
Avalonman's Avatar
View Avalonman's Photo Gallery
All 07 Camry's have the foot pedal parking breaks. The Manual Transmission has the Hand Lever.
Avalonman is offline   Reply With Quote
Old 01-13-2007, 09:36 AM   #10 (permalink)
View onsknht's Photo Gallery
Where did you get that chart? The 07 Camry click adjustment is as follows.
Automatic with foot pedel = 7 - 10 notches
Manual with hand brake = 7 - 9 notches
Next... You fellas do understand that while you have rear disc brakes.... The parking brake works like a drum brake within the hub of the disc?
This is why someone was able to "back out" when the brake was lightly depressed but the car wouldn't move forward.
2GR-FE
onsknht is offline   Reply With Quote
Old 01-13-2007, 09:27 PM   #11 (permalink)
Aren't you just repeating the specs for th parking brake settings that I just posted?
Those are the service specifications provided by Toyota.
Anyhow, the dealer adjusted my brake and all is well. My car will hold with 5-8 clicks depending on the grade.
2007 Camry 2.4L 5M
Old 01-14-2007, 04:41 PM   #12 (permalink)
crazydesiforever
avnishghei's Avatar
View avnishghei's Photo Gallery
Gen6
hey is ther any way to tighten up the pedal brakes on the 07 camrys??
07 Camry Metallic Blue: Phillips HID 4300k,
Hella Optilux Fogs, Internal Blue LEDs & Cathodes
Tints, Chrome Exhaust Tip, Rear Spoiler, TRD Lowering Springs
6x9 Pioneer All Around & Custom RockfordFosgate 12" P3
avnishghei is offline   Reply With Quote
AE92 & AE82 Brake upgrade options.... freakinbox Older Generations (1969-1987) 8 09-13-2007 04:41 AM
Brake Problem Babar Introduce Yourself Here 0 10-28-2006 03:52 AM
99 parking brake problem jeprox 1st Generation (1998-2003) 2 03-22-2006 01:45 PM
Parking Brake ? MR2Jedi MR2 Forum 12 10-18-2005 01:39 PM
Parking Brake lights [Help] dropyopanties Camry & Solara Lounge 4 10-18-2004 02:24 PM
