New Rims/ TPMS sensors? - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-03-2007, 03:19 PM   #16 (permalink)
BigWillie's Avatar
View BigWillie's Photo Gallery
Thumbs down
Well that sucks ass! I still think this system is useless. Just another dealer only service that you can get hosed for! I really miss my '03 Tundra...WHY...WHY....WHY did I trade!?!?!?!? *cocking hammer back on the revolver*
BigWillie
2007 Camry LE I4 Auto - Magnetic Grey Metallic / Bisque cloth..............
Live Free or Die!
BigWillie is offline   Reply With Quote
Old 01-04-2007, 10:24 AM   #17 (permalink)
View Import Tire's Photo Gallery
Originally Posted by wilfredcruz
When you reset it, as th emanual says. all you are doing is reseting the threshold pressure. The sensors will detect the difference in pressure, not the actual pressure at a given time, for example if you reset your set and your pressure was a 32 the light will come on once the pressure drops to 6lb (??) under the set value of 32psi. .If you reset it at 25 psi then the light will come up once the pressure drop 6lb under 25!. Read the manual. The sensor doesn't know the actual pressure on tire, it will only "see" the difference in pressure.
If you change your sensors you need to input the sensors ID in the Toyota ECM, to do that you need to have a Toyota programmer for the ECM (cost a lot of cheeseburgers). There are other vehicles that you just reset it and thats it, NOT with the Camry you need the ID in the ECM to have communication.
This is not quite true. The reset button under the dash does not reset the threshold pressure. The reset button under the dash allows you to rotate the tires and have the system detect the new locations for the transmitters.
However, if you replace a transmitter on the Camry, then yes you will need to have the sensor id entered into the ECM. Toyota is the only manufacturer that this reprogramming is required afaik...all the others you just press the reset button, it finds the new sensor and you are good to go. As an independant tire dealer, the introduction of the TPMS systems has led to a lot of confusion and misinformation, as well as added time and cost. The owner's manuals don't always indicate the correct procedure (as is the case on the Camry). Most dealers I've spoken with hate the TPMS systems as well because of the amount of time required.
Oh yeah, and something to think about...the valve stems which are part of the sensor are exposed to the elements all the time. For those of us in the areas where salt is used on the roads, the sensors are going to start to corrode sooner rather than later. Sensors for most GM's run about $50 each. Sensors for most Hyundais run about $10 each. Sensors for most Toyotas run $100 to $200 each! And they're all similar technology.
Robert
Import Tire Co.
Import Tire is offline   Reply With Quote
Old 01-04-2007, 12:11 PM   #18 (permalink)
BigWillie's Avatar
Robert
Import Tire Co.
So I was right about using the button to reset the system, but it seems I have cold weather issue 'below freezing', any ideas? I checked my air pressure one morning when at the freezing temps and it was 30 PSI and isn't the system set to go off at 25 or 26 PSI?
I'm sorry, am I getting off topic!?
BigWillie
Live Free or Die!
Old 01-04-2007, 01:48 PM   #19 (permalink)
Sounds like there's some water in the system somewhere. I don't buy into the Nitrogen hype, but you may want to replace the air in the tires with Nitrogen to see if the air that was used to inflate them when you last had them changed had a little too much water in it. That could be condensing and freezing on/in the sensor and causing the problem. If you can't find a place that has nitrogen, replace it with 'new' air, hopefully from a dryer source. Also, the next time you have the problem, you could bring the car to a tire dealer and have them use a TPMS diagnostic tool to determine which sensor has the problem.
Also, don't forget to check the spare tire pressure...it has a sensor as well.
As far as what pressure the system will signal a problem at, I think it may be as little as 2 to 3 psi below the recommended pressure, which is indicated on the sticker on the door.
Good luck, and let me know what you find out.
Old 01-04-2007, 02:06 PM   #20 (permalink)
SEcond Rate Products
View repocop's Photo Gallery
mine don't even work anymore, i took my car in to get the oil changed, asked that they fill the tires to my usual pressure because they felt very low (36psi, comfort be damned) and he told me they were all 4 at 19PSI
... no light.
*shrug*
2007 Camry SE V6
| Barcelona Red Metallic | Custom Intake | TRD Springs | 15" Dayton Reference Sub | Enkei RP-F1
repocop is offline   Reply With Quote
fix bent rims or get new ones? TRD_girl Archived Corolla threads 16 09-25-2007 10:16 AM
My expertise on rims and tires SpectraBlueCam Hardcore Tech and Competition 57 10-13-2006 11:54 PM
Tire Pressure Sensors IndiBlue4x4 2nd Generation (2005+) 4 04-08-2006 07:41 PM
Opinions needed on some rims. HELP PLZ. WreckedSt Celica Forum 3 10-04-2004 05:29 AM
