2007 Camry, B-Pillar driver side rattle - TSB? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-08-2007, 10:59 AM   #1 (permalink)
View proteus220's Photo Gallery
Has there been a TSB fix for the drivers side b-pillar rattle for the 2007 Camry? I have searched and have found nothing. I have attempted to remove the panels to pinpoint the rattle noise before, it went away for awhile but now if back in full force. The noise sounds like a metallic rattle around where the seat belt anchor is located or the upper side of the window near the b-pillar. I can apply slight pressure against the driver's door and it will go away.
Or if someone has "fixed it themself," care to post the solution?
Dealer says it's "normal" or "i don't hear it" on test drives, and if they dismiss the issue with such uncaring attitude, the last thing I want is them tearing everything apart.
Thanks for anyone's solution.
proteus220 is offline   Reply With Quote
Old 01-08-2007, 05:31 PM   #2 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
Not for a rattle..................
BO015-06 RH INTERIOR A-PILLAR GARNISH LOOSE
7/28/2006 - 2007 model year NAP-built Camry vehicles produced BEFORE the Production Change Effective VINs shown
Some customers may complain that the right side interior A-pillar garnish is loose or out of position. This condition is caused by an incomplete installation of the A-pillar garnish at the factory. Follow the repair procedure in this bulletin to correct this condition.
BO017-03 TRIM GARNISH LOOSE (REVISED)
4/24/2006 - 1991 – 2007 model year Toyota vehicles.
Customers may experience an interior trim panel either loose or fitting poorly due to a deformed or missing panel attachment clips. When a trim garnish (A, B, C, or D pillar garnish, door trim panel, etc.) is removed and reinstalled using the old clips, there is a possibility that the garnish may exhibit a loose condition. To prevent this condition from occurring, please use the following procedures.
Old 01-18-2007, 12:18 AM   #3 (permalink)
View kchang's Photo Gallery
anyone figure out what's causing this clicking problem?
kchang is offline   Reply With Quote
Old 01-18-2007, 10:29 AM   #4 (permalink)
'07 XLE
Gen6
I don't hear that clicking.......................
Overall Comparison: Toyota Camry XLE V6 v.s. Pontiac Grand P CamryLeb Camry & Solara Lounge 25 08-13-2007 10:55 PM
Official 2007 Toyota Camry Announcement, Images & Specs EKam Toyota News 1481 05-17-2007 09:50 PM
Complete 2007 Camry Crash Test Results.. PERFECT! islandboy57 5th & 6th Generation (2002-2006 & 2007-2011) 3 08-08-2006 06:43 AM
