Transmission Flare - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-13-2007, 11:37 AM   #1 (permalink)
View bmullikin1's Photo Gallery
Gen6 Transmission Flare
ANYONE TRIED CHANGING TRANSMISSION FLUID TO A HI PERFORMANCE AFTERMARKET ONE TO SEE IF IT HELP IN THESE PROBLEMS,READ ONE POST THAT TRANSMISSION FLUID TEMP WAS A PROBLEM UNTIL WARMED UP . ANY INPUT 6CYL SE PEOPLE.
bmullikin1 is offline   Reply With Quote
Old 01-13-2007, 12:01 PM   #2 (permalink)
Gameroom cash: $232150
View Joe B's Photo Gallery
The Camry uses a WS type fluid.
$42 a gallon at Toyota.
I know Amsoil doesn't make a compatible fluid.
'11 Camry Hybrid Classic Silver/Ash
Moonroof | NAV | Leather | JBL Audio | XM | Blue Tooth | OEM Remote Start | Michelin Primacy MXV4
'11 Honda CR-V EX-L w/NAV 4WD Glacier Blue/Gray
Leather | Remote Start | Fogs | Premium Sound | XM | Wood Dash | Michelin Primacy MXV4
Joe B is offline   Reply With Quote
Old 01-13-2007, 12:50 PM   #3 (permalink)
View djpeetur's Photo Gallery
I have a 5pd SE, but i asked about the transmission and the service advisor told me , people arent use to driving a DRive-by-wire. i was lik wtf?
djpeetur is offline   Reply With Quote
Old 01-13-2007, 01:47 PM   #4 (permalink)
View onsknht's Photo Gallery
He's right! Sort of... There is a diff between a cabled car and DBW, the DBW being more sensitive and having a multitude of additional "modes" based upon the various inputs from all the different sensors.
BUT - the shift flare problem is NOT caused by inexperienced DBW users... Further, fluid will not change the condition, especially full synthetic because it is thinner. The problem is the result of a faulty check valve allowing fluid to drain causing a "bubble" in the valve body... As the trans fluid builds pressure, the bubble isn't release and when the trans calls for 3 to 4 shift.... BBBBBUUUUUURRRRRP! You get shift flare.
2GR-FE
onsknht is offline   Reply With Quote
Old 01-13-2007, 02:37 PM   #5 (permalink)
Posting via Handheld
wireless's Avatar
View wireless's Photo Gallery
Hey, you figured it out. Now aren't you kicking yourself for taking it in the shorts. If you had only waited a few weeks.
j/k
This is where you insert your signature
wireless is offline   Reply With Quote
Old 01-13-2007, 03:08 PM   #6 (permalink)
71Corolla's Avatar
Gameroom cash: $548750
View 71Corolla's Photo Gallery
Very interesting. I'm curious, how do you know this is the exact cause? It sounds reasonable though..
71Corolla is offline   Reply With Quote
Old 01-13-2007, 03:31 PM   #7 (permalink)
j/k
Unfortunatetly for whatever reason, there's still the difference whether the valve body fixes the issue or a check valve.. I'll have to look closer at the workings of the valve body... It may be that prior 07/06 builds there's an issue with a solonoid or something. Post builds may have introduced the check-valve problem which may be deeper than a valve body.
This was the rationale provided as to why my transmission was not a candidate for the TSB as originally written but instead called for replacement as it was built after 07/06.... When I get a little more downtime I'll look through the FSM and see if I can locate more precisely what was described.
2GR-FE
Old 01-13-2007, 04:19 PM   #8 (permalink)
71Corolla's Avatar
Thanks for the answer.
The burning question for me remains, is the 6 speed transmission inherently flawed? Are there different revisions, some of which show the flare problem? Are there units that cannot be repaired, others that can? Are there any V6 models that don't have any flare problems or shift problems in general at all?
I'm gonna be a nervous wreck when I pick up my new car.
Old 01-13-2007, 04:41 PM   #9 (permalink)
it is what it is
akira751's Avatar
View akira751's Photo Gallery
Gen6
MySE V6 runs great, no issues at all.
07 Camry SE V6, Nav Mag Grey,18" Nex-0 gun metal, Trd Springs,K&N Typhoon Intake
http://www.cardomain.com/ride/2475669
akira751 is offline   Reply With Quote
Old 01-13-2007, 05:07 PM   #10 (permalink)
wireless's Avatar
Still no issues since Day 1 post TSB.
Old 01-13-2007, 07:08 PM   #11 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $186325
View JSM1284's Photo Gallery
SE V6 14,000 miles, NO Problems!
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Old 01-13-2007, 07:33 PM   #12 (permalink)
"Two Tacos"
west467's Avatar
View west467's Photo Gallery
LE V6, 8000 miles no major problems...I did notice a shift flare around 4000 miles, very minor, only a few times. I have tried to make it flare, hot, cold, slow, fast...could not duplicate the flare. I drive it in various ways, and run it hard a few times a week.
I am starting to like my Camry more and more..I hope it holds up!!!
June 2006 Build
west467 is offline   Reply With Quote
Old 01-14-2007, 08:41 AM   #13 (permalink)
No issues here either.
Old 01-14-2007, 08:54 AM   #14 (permalink)
View patgood01's Photo Gallery
Gen6
Never had any problems. I'm at 4700 miles.Except for squeaks and rattles.
patgood01 is offline   Reply With Quote
Old 01-14-2007, 09:05 AM   #15 (permalink)
LEmon V6
View Midnight2's Photo Gallery
Excellent explanation! Why hasn't Toyoi. figured this out? Seems simple to me.
Midnight2 is offline   Reply With Quote
HELP: Serious Transmission Problems arcasmachineracing Camry & Solara Lounge 23 06-22-2008 11:53 PM
1st issue with 07'Camry AESANTIAGO 5th & 6th Generation (2002-2006 & 2007-2011) 949 01-08-2008 02:49 PM
Transmission Flare *** SOLVED *** onsknht 5th & 6th Generation (2002-2006 & 2007-2011) 127 01-03-2007 09:44 PM
Found a $350 camry, but not sure if i can fix it Figit090 1st & 2nd Generation (1983–1986 & 1987-1991) 37 01-02-2007 02:29 PM
Transmission failure. Very sad. alchu Camry & Solara Lounge 1 06-14-2004 10:06 AM
