Can somebody show me diagram how to take off the front bumper? - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-31-2007, 05:11 PM   #16 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $186325
View JSM1284's Photo Gallery
10MM socket(most of them), and a Phillips Screw-driver(for two top bumper screws), Flat-head (for the fender well clips)
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Old 01-31-2007, 10:01 PM   #17 (permalink)
View TitaniumSE's Photo Gallery
^ Also, where can I find a 10mm socket wrench? I just need one, not a whole set. I couldn't find any at Pepboys =[. Would Home Depot be selling one?
TitaniumSE is offline   Reply With Quote
Old 02-01-2007, 01:09 AM   #18 (permalink)
JSM1284's Avatar
Either there or sears
2005 Lexus ES330
Old 02-01-2007, 07:24 AM   #19 (permalink)
n8dogg455's Avatar
View n8dogg455's Photo Gallery
Starting with the hood open, take out that 10mm hex black screw in the middle. Then take a philips #2 tip and take out the two rubber bump stops for the hood (one toward the driver and one toward the passenger side). Then... along the same area you'll notice a bunch of plastic pushin round tabs all along that area. You ONLY need to take out 1 near each of the headlight. And it would be the Second To Last on each side. So not the one that's right next to the headlight, but the second one away from the headlight.
That basically completes the top.
Under the bumper on the permeter will be a bunch of grayish 10mm socket hex screws so remove those. Then when you get to either end, there will be a BLACK 10mm socket hex screw. Only take one out from each end, the one on the edge of the bumper, you don't need to remove the other 2 next to them.
Then in your wheel well, in front of each tire you'll noticed a plastic tab. Take a flat screw driver and turn it 1/4 turn. Then pull it out, like all the way out. You can't leave part of it in there, you have to pull it out, either take a plyer or something.
One last 10mm hex gray screw is behind that wheel well flap. You can take a screw driver and push the black flap away where the bumper meets the fender. You'll see that 10mm gray hex screw. Just remove it with a socket or a philips screw driver.
also if you have the air dams infront of your front wheel, you also have to remove 2 screws, there to get the bumper off
Pull on each side of the bumper. Pull it forward and at the same time lift the bumper up so the top of the bumper (where it meets the hood) can come off the rails.
And that's it. When I first took it off, i had the car on a lift so I took all the black plastic panels underneith the car off too hehe which wasn't needed. But when you put it back together, you have to make sure part of those black panels slide into the bumper and some of it doesn't. The ones where you took those gray 10mm hex screws are the ones that has to be on the outside or below the bumper, not into it.
~07 Magnetic Grey SE I4 ~
FX35's ~ 4300k Philips D2s ~ Matsushita Gen3
Blazers ~ Side Indicators ~ 6 Superflux Per
40% Silver Tint ~ 36 LEDS In My Trunk ..... http://www.putfile.com/n8dogg455/images
Next Projects: IS300 Fogs ~ Superflux Tails / Turns / Reverse
n8dogg455 is offline   Reply With Quote
Front Bumper Questions obeycamgiant Camry & Solara Lounge 0 04-23-2006 08:53 PM
TN exclusive Gen3/3.5 body kit - FRONT BUMPER ONLY - VOTE BLUEMEANIE 3rd & 4th Generation (1992–1996 & 1997–2001) 89 05-04-2004 03:31 PM
Camry Front Bumper Removal saltypig Camry & Solara Lounge 5 01-21-2004 04:13 PM
