Originally Posted by dirtdiggler
...since trying to remove the center storage bin is more involved.
This is actually quite easy.
1) Unscrew your shift knob.
2) Shift the gear all the way down, so it is out of the way.
3) Remove the side fins on the center console
4) Pull off the center console cover
5) Remove the two screws holding the storage bin in place.
6) Pull out the storage bin, you will need to unhook the power and aux connections from the rear of the bin.
The above should not take you more than 5 minutes.
These two links have pictures that will show you how to take apart the dash. The first link will show you about the fins and center console cover, the second will show you about the center console stack.
Gen6 Rattles, crackles, and noises
http://www.greenhybrid.com/discuss/s...ad.php?t=11672
