Originally Posted by njerald
I posted the TSB. I'm not going to hold your hand and do your SEARCH...
I searched for all of your postings to this thread:
"Answered in the other thread that you asked the same question!!!!!!!!!!!!"
"Sayonara........."
"The French are wrong, AGAIN!!!!"
"Just because the tube is white means nothing.
You have evaporator and heater cores that you cannot see in the heater housing.
Yes there is a drain from the air inlet. If you want to know where it is, take a pail of water or a hose and try to fill it up. If the drain is clear you will see it. If not the air inlet will up and you will end up with water coming into the filter.
You will end up with the same problem that everyone else in this thread had.............."
"I posted the TSB. I'm not going to hold your hand and do your SEARCH..."
I read this entire thread, noting every mention of a recall or TSB:
In message #30 of this thread, lollonais stated that his wife was told there would be a recall for this problem.
In message #36, akide forwarded a message from Toyota Canada saying to either have the dealer clean it or try pouring 1:5 diluted isopropyl into the outside air intake.
Message #79, msanfilippo said, "They have even pulled down the entire dash to replace the evaporator, etc." but no mention of a TSB.
Message #134, cjgcamry2005 stated, "Both dealerships told me that it was a common problem with the car and toyota was working on a fix."
I searched for odors and TSB and found one - for 2009/2010
Corollas T-SB-0384-09.
If you know of a TSB for the Camry concerning odors or smells, could you please provide a link to your port or a TSB number to search for?
Thanks
