Originally Posted by djkor
Like I said, believe what you want to believe. Even feel free to believe yourself that it really makes a difference after you do it for yourself.
If you know anything about physics, you will know that air is a bad conductor of heat. With the small internal surface area of the throttle body, a difference in temperature of 23 degrees as quoted above is not going to be able to heat up the volume of air that passes through it significantly enough to reduce power.
Anyone who really thinks they are getting a positive gain out of this really should read up on how to properly modify a car for performance.
You go and get all 'physics' on me. Then say I'm believing in stuff like like I have pulled this out of some fairy tell land or something.
I have only shared what other's have experienced and was asking for people's personal experience here.
For instance...how does physics explain this --->
http://www.lt1tips.com/lt1-dyno-graph.html
LT1 Throttle Body Dyno
The dyno shows a 6.3 horsepower and 7.1 ft/lbs torque increase on a stock 96 Trans Am.
Maybe that is just a random number perhaps or that person and the dyno operator didn't know what they were doing?!?
Beats me!
I was asking if anyone had actually did that mod (You have) and what their experience was while doing this (You shared this). That's cool! However....I have been told the 'That won't work' and 'That will not gain you any hp/tq' speech before with the intake and exhaust too. I have dyno proof it works...on this engine....although on a vehicle slightly different. Same engine though! Been told going to lighter wheels won't help lower 1/4 mile times too, by some people. 1/4 mile times dropped again.
So just like you, I test these things but ask for people's experienced thoughts on them. What IF I do this mod and somehow manage to get a better 1/4 mile time or trap speed under similar conditions. Would you call it luck? Chance perhaps? I'm here to learn as much from the Camry peeps as I can. Love the v6 Camrys and was considering getting one but the wife wanted more utility so....
Maybe I just happen to get a slightly better 1/4 mile time than you because I keep believing in fantasies. Perhaps the track timers down under are a little more accurate than here in the states. Got me! I'll continue to learn as much as I can from you even if you keep belittling any type of modification I consider. I have a lot of respect for you and many other people in this community. My options are wide open and no tunnel vision here. I'll go back now to being the good student. You seem to know your stuff! I'll continue to play the 'Ricer, Fast & Furious' role. **Watching you**
