Where can I get switches for these slots on my Gen5? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-18-2007, 11:04 PM   #1 (permalink)
I Want My MPG
View sn1cko's Photo Gallery
Gen5 Where can I get switches for these slots on my Gen5?
I've seen switches as part of the fog light kits on Ebay, but I want to put switches here for other applications.
Does anyone know a good source for a switch that could simply replace these slots?
While I'm on this topic, what does the factory/oem usually use these slots for?
sn1cko is offline   Reply With Quote
Old 03-18-2007, 11:08 PM   #2 (permalink)
Under Reconstruction
Epsilon's Avatar
View Epsilon's Photo Gallery
Are you looking for a fancy switch or oem looking switch?
Epsilon is offline   Reply With Quote
Old 03-19-2007, 01:38 AM   #3 (permalink)
I Want My MPG
Pretty much anything that's a clean replacement. I just want to pop the panel out and pop a switch in.
Old 03-19-2007, 01:44 AM   #4 (permalink)
Epsilon's Avatar
You can use any two way switch (ON/OFF) from your local Autozone, Pepboys, etc. Just cut enough of the panel to integrate the switch to it and you will have a perfect fitting switch that uses the stock panel.
Old 03-19-2007, 02:34 AM   #5 (permalink)
touringcamry's Avatar
Gameroom cash: $510625
Yup, just find a regular switch from the sources Epsilon mentioned, Radio Shack, or Frys. Cut some of the material out and put the switch in. The switch will come with a bezel that will be slightly larger than the cut out to make it look cleaner.
2007 Camry 2.4L 5M
Old 03-19-2007, 02:45 AM   #6 (permalink)
Epsilon's Avatar
You can always use these:
Old 03-19-2007, 03:11 AM   #7 (permalink)
I Want My MPG
Making a cutout in those little panels is pretty much what I had in mind at the moment;
I wanted to know if there were switches that would take up the whole rectangle slot like the switches
included in these ebay kits:
But I wouldn't want the "fog" label on it. Unless I've been mistaken and
these ebay switches don't plug in exactly to those slots.
Do you guys know what the factory uses these slots for? If they were for
switches, maybe I could just go to the dealer and get them...but they might
be labeled for their intended function.
I'm just being nitpicky now and wanted to see my options before cutting these
things to fit in a switch. Nonetheless, thanks for the tips, guys!
Old 03-19-2007, 03:52 AM   #8 (permalink)
HID/Retrofit Expert
white3ch0c0late's Avatar
iTrader Score: 7 reviews
View white3ch0c0late's Photo Gallery
^Those fog switches do in fact fit into those slots.
2009 Audi TT 2.0T --- THE BEAST!
2002 LE 4Cyl --- Gone, but not forgotten. 06/28/09
Glaring blue HID bulbs are NOT classy, and don't make your car look nice, no matter what that kid in the Civic told you.
white3ch0c0late is offline   Reply With Quote
Old 03-19-2007, 11:08 AM   #9 (permalink)
MAR
Future Toyota Engineer
MAR's Avatar
View MAR's Photo Gallery
Those slots are for the traction control and the stability control (V6 only)
MAR is offline   Reply With Quote
Old 03-19-2007, 03:50 PM   #10 (permalink)
einstein's Avatar
View einstein's Photo Gallery
i used mbenz switches on my 5 gen. have alook in my cardomain pag for the cam. look under garage door opener and blinking led.
xrl.us/camman
http://www.cardomain.com/ride/2379797/1
A picture is worth 1,000 words!
einstein is offline   Reply With Quote
Old 03-19-2007, 07:08 PM   #11 (permalink)
2003 Camry Speedster
View IPDaily's Photo Gallery
how come my XLE doesn't have a switch for traction control?
2003 Toyota Camry XLE V6, 18x7.5" ASA rims +40mm offset, Bridgestone Potenza Tires 225/45/18, H&R Sport Springs, TRD Exhaust/Strut Tower Brace/Rear Sway Bar, Wood Steering Wheel, 20% LLumar Tint
2007 Toyota Camry SE V6, Sport Leather
IPDaily is offline   Reply With Quote
Old 03-19-2007, 09:57 PM   #12 (permalink)
2011 BMW 535xi M-Sport
pillpusher84's Avatar
View pillpusher84's Photo Gallery
I wish my 07 XLE had a control for VSC ON/OFF ... Can't even spin the tires if you wanted to! LOL ... on the other hand my 98 ES300 has it & so does the 07 ES350 ... wtf???
Current Rides:
2011 BMW 535i M-Sport xDrive (Mine), 2010 Infiniti G37S Convertible (Wife's), 2010 Toyota Rav4 Base 4cyl (Dog-mobile)
Previous Rides:
2010 Lexus RX350 AWD, 2007 Lexus GS350 AWD, 2007 Camry XLE V6, 2005 Acura TL, 2003 Nissan Maima SE, 1998 Lexus ES300
pillpusher84 is offline   Reply With Quote
Old 03-19-2007, 11:54 PM   #13 (permalink)
I Want My MPG
xrl.us/camman
Those are some pretty clever things you got going on your car That's nice to see some of those switches from other cars fitting nicely; that's what I was looking for. I'm going to have to look for something similar
Old 03-20-2007, 02:01 AM   #14 (permalink)
& JustAnotherCamry
View JustAnotherAsian's Photo Gallery
^from kragen. not the best, but they filled the rectangle.
edit: you can change the lens color (green, amber, red, and blue are included) and the label thingy (fog [shown], defroster, headlight, and other random lables included).
there is a millimeter gap as you can see from the pic, but it's not noticable from most angles.
JustAnotherAsian is offline   Reply With Quote
Old 03-20-2007, 02:56 AM   #15 (permalink)
I Want My MPG
^ that looks clean enough, thanks for sharing!
Power window switches on drivers door stopped working on 96 Camry. TommyN 3rd & 4th Generation (1992–1996 & 1997–2001) 5 01-12-2008 12:26 PM
Accessory Switches (in place of the dummies) jdavis 2nd Generation (2005+) 40 02-05-2007 05:23 PM
One Touch Window Switches onsknht 5th & 6th Generation (2002-2006 & 2007-2011) 30 09-29-2006 04:49 PM
Sway Bar for JDM Gen5 sqcamry2003 5th & 6th Generation (2002-2006 & 2007-2011) 3 10-05-2005 01:25 PM
Gen5 V6 Aftermarket Parts fahad_600 5th & 6th Generation (2002-2006 & 2007-2011) 2 01-13-2003 02:07 PM
