H11 Headlights - Page 4 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-21-2007, 10:51 PM   #46 (permalink)
Here and there...
Gameroom cash: $153229
iTrader Score: 6 reviews
View lammydi's Photo Gallery
Originally Posted by mannypeligroso
Moky,no offense taken.I suppose there's different ways to change the bulb and it seems everybody may use a different technique.They may be fast or slow at it depending on what technique they use.If you can reach the wiring harness and change the bulb in that manner and do it in a minute then thats cool.In my case the mechanic removed the panels of the headlight assembly to reach far back and get to the bulb.I guess maybe thats just the way to do it in some cases without being sloppy or leaving any lose ends.And maybe he took longer because he was being careful and didn't want to break anything.But judging from the fact that you can do it in a minute then obviously there's other loopholes you can find to replace the bulb without removing the panel.I just finished talking to experts in the area and they recommend removing the assembly,but other experts may disagree and choose another way to replace the bulb.
Also replying to another member,lammydi... It seems you are very desperate to prove me wrong considering that you're here asking people if it my hybrid has the same type of bulb and adapter.Suppose it has the same layout like all the other trims of the camry,then have I not proved my explanation why for some people it may take a minute and for some longer up to 15 minutes or longer.Maybe if I went to center that specializes in car lighting then they may be able to do it in a minute like you suggest.But for most people that are not specialists in that area like myself its not as easy as a minutes job depending on the technique that you chose.The fact of the matter is if you don't know what you're doing and don't know too much about cars then I think going to a shop and spending a little money in all likleyhood may be the best option if you decide to buy those mtec bulbs.
I am not desperate to prove you wrong.....it just 1 of those things that it would bug me all day long if I can't find the answer. I am no expert in car at all. I am just like most of the members here....when I don't know I will ask around.
Old 03-21-2007, 10:57 PM   #47 (permalink)
Support Authenticity!!!
moky-tron's Avatar
View moky-tron's Photo Gallery
+1 to lammy di!
manny, im not claiming to be an expert on changing bulbs. maybe you should try looking in your engine bay, and see if you can reach the harness and the bulb itself. maybe due to circumstance where your hand doesnt fit the area...then... maybe its time to take a few things apart.
moky-tron is offline   Reply With Quote
Old 03-22-2007, 08:35 AM   #48 (permalink)
I'm Cam'd Up
Pimpinda93camry's Avatar
View Pimpinda93camry's Photo Gallery
i thinlk it was smart of manny to get it done by a pro.
becasue if he would of tried for an hour like i did on my brother old focus then he had a frustrating time then if you think you did the right think then more power to you.
and like every one else says that are not jerks "to each His own"
****NEW 1970 CHEVY NOVA**** MORE INFO LATER
Cold Air Intake
Cat Back Muffler, 5% Semi Matelic Tint
16x7 Proline Alloy, Dunlop SP FM901 225/50/R16
Clarion HU, JL Slash 500/1 , 2 JL 10W0, Silver Star Headlights
Pimpinda93camry is offline   Reply With Quote
Old 03-25-2007, 08:00 AM   #49 (permalink)
X72
View X72's Photo Gallery
Originally Posted by Burnes
I can't find any good H11's(other than standard), does anyone have any links or brands of some good ones to buy?
Click on http://www.danielsternlighting.com/p.../products.html
and then scroll quite a ways down to the picture and description of the H11 bulb where Daniel Stern reports that an H9 bulb (65 watt) will fit where a H11 bulb fits. He reports that some lamps have the optics to handle the much greater light output of the H9 bulb as compared to the H11.
You could consult with Daniel Stern. I have no personal experience with him but he seems quite knowlegeable. Read his scathing criticism of HID conversion kits. http://www.danielsternlighting.com/t...nversions.html
I would first make sure that the lamp is correctly aimed before changing bulbs though.
X72 is offline   Reply With Quote
Old 03-25-2007, 09:03 PM   #50 (permalink)
BANNED
View w203's Photo Gallery
Very similar concept to the 9006-->9005 conversion.
What most people experience after doing that is the shorter lifespan for the bulbs. Some cars are equipped to handle the increased wattage and those are usually the higher end cars (the lower end tends to cheap out). It also depends on how long your bulbs are on etc. A risk I'm not willing to take since the stock lighting output is adequate.
w203 is offline   Reply With Quote
Consumer Reports on HID Phi General Discussion 28 01-17-2007 08:23 PM
Real HID's not necessarily "better" fredster34 5th & 6th Generation (2002-2006 & 2007-2011) 26 12-11-2006 06:06 PM
93 Headlights simms 89-95 Toyota Pickup/Hilux 3 07-03-2006 11:14 PM
Clear Headlights.......Come look! luisitol Camry & Solara Lounge 34 07-02-2005 08:47 AM
