How Difficult to Remove Metal Gas Filler Pipe? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-26-2007, 07:18 AM   #1 (permalink)
View Demiandvm's Photo Gallery
Hello All:
Autozone diagnosed the reason for my check engine light to be on is due to poor seating of the gas cap and metal filler neck. There is some corrosion on the metal lip surface. How difficult is it to remove the pipe in order to wire wheel it smooth (don't want to perform on car with fumes and all) or should I just replace with a new one? Does one approach pipe through the trunk or from underneath behind wheel well? Thanks for any insight or advice that may help!
Michael
2003 Camry 4 cyl
Demiandvm is offline   Reply With Quote
Old 03-26-2007, 05:42 PM   #2 (permalink)
View Boston Redneck's Photo Gallery
Gotta love the Autozone diagnosis
Anyhow, if you want to do this repair, don't use a wirewheel, just some good sandpaper will smooth that down and use alittle silicone spray on the rubber seal of the gascap. I have done it this way on maybe 10 cars and never had a comeback.
If you do want to pull the neck assy, it's really not that difficult and you won't need any special tools to do the job.
Boston Redneck is offline   Reply With Quote
Old 03-26-2007, 06:29 PM   #3 (permalink)
BANNED
View w203's Photo Gallery
Can you take a pic of what your referring to? I think I have an understanding but want to be 100% sure. But you can plug the gas hole with a rag or something to block it and sand it smooth but the problem might return. Are you sure your gas cap isn't just closed properly?
w203 is offline   Reply With Quote
Old 03-27-2007, 02:00 AM   #4 (permalink)
View toyomoho's Photo Gallery
Might plug the filler pipe with rags and hand sand with water and water proof paper. The pipe should come out easy enough though, see what Toyota wants for one or find a junk yard. Or try doubling up on the cap gasket and see what happens, the dealer should have them.
Old 03-27-2007, 07:14 AM   #5 (permalink)
Thanks for the advice--i'll try the wetsand idea.
Michael
DIY Custom CAI - 56k Sorry Brujo Camry & Solara Lounge 50 07-08-2009 03:01 PM
Fullsize spare hybridamp 5th & 6th Generation (2002-2006 & 2007-2011) 13 01-24-2007 08:56 AM
Silver Paint - Poor Quality? hybridamp 5th & 6th Generation (2002-2006 & 2007-2011) 30 01-10-2007 09:53 PM
89 block mounted cooling pipe capped off? jmill89 Supra Forum 3 11-27-2006 11:03 PM
DIY Cold-Air Intake bondobondo Hardcore Tech and Competition 40 11-24-2004 01:41 PM
