245/45zr18 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-02-2007, 11:29 AM   #1 (permalink)
View bwbazemo's Photo Gallery
245/45zr18
Has anyone put this tire size on an 2007 Camry 245/45/ZR18 yet.I was thinking of running this size and was curious if they would fit or not (or would they scrub?)
Thanks
Brandon Bazemore
bwbazemo is offline   Reply With Quote
Old 04-02-2007, 11:41 AM   #2 (permalink)
View cbra928's Photo Gallery
i was curious if 245/40/18 would fit the Gen5.5 also
2005 Camry 2.4
Injen Intake
Magnaflow cat back
TRD Springs & Strut Bar & KYB Struts
cbra928 is offline   Reply With Quote
Old 04-02-2007, 12:24 PM   #3 (permalink)
Here and there...
Gameroom cash: $153229
iTrader Score: 6 reviews
View lammydi's Photo Gallery
Thanks
Brandon Bazemore
Brandon,
It would fit no problem. You can go to the www.tire.com to see it for yourself. Just click on the tire calculator to compare any tire size.
Your stock is 215-60-16 which have the overall diameter of 26.16 inches.
Your new tire is 245-45-18 which have the overall diameter of 26.68 inches. It is only an increase of 1.99% or round up 2% compare to your stock. Generally rule of thumb is to keep it withing +/- 3%. This new tire will fit no problem and still within the guideline.
Old 04-02-2007, 12:32 PM   #4 (permalink)
Here and there...
Your new tire is actually an increase of 4.2% over the stock tire.
Overall diameter of new tire is 25.72
Overall diameter of original tire is 24.69
It will still fit because I know a lot of people driving Gen5 with 245-35-20 tires.
But it is over the +/- 3% rule of thumb. So your odometer will really be off.
I would suggest you go with 225/40/18 or 235/40/18.
Old 04-03-2007, 12:44 PM   #5 (permalink)
Under Reconstruction
Epsilon's Avatar
View Epsilon's Photo Gallery
How wide are your new wheels?
Epsilon is offline   Reply With Quote
Old 04-03-2007, 05:46 PM   #6 (permalink)
I think they r 18x7.5 or 18x8 I have 225 40 18 right now....I would like to go wider 235 or 245 I just dont know if it wil rub or not...
2005 Camry 2.4
Injen Intake
Magnaflow cat back
Old 04-03-2007, 09:15 PM   #7 (permalink)
2011 BMW 535xi M-Sport
pillpusher84's Avatar
View pillpusher84's Photo Gallery
Thanks
Brandon Bazemore
I just put 245/40ZR18s on my 07 XLE ... no rubbing at all. You will definately have no problem, as the only difference is the Profile, and theres plenty of room to go larger on the profile ... however, I'd go with the 245/40ZR18's for two reasons:
1. They look better ... less sidewall!
2. They keep closer to stock diameter, which will keep your speedo, odometer & NAVI as close to factory as possible to keep things accurate!
Current Rides:
2011 BMW 535i M-Sport xDrive (Mine), 2010 Infiniti G37S Convertible (Wife's), 2010 Toyota Rav4 Base 4cyl (Dog-mobile)
Previous Rides:
2010 Lexus RX350 AWD, 2007 Lexus GS350 AWD, 2007 Camry XLE V6, 2005 Acura TL, 2003 Nissan Maima SE, 1998 Lexus ES300
pillpusher84 is offline   Reply With Quote
Old 04-03-2007, 09:22 PM   #8 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Gameroom cash: $149932
View Yazovets's Photo Gallery
What does it matter if the odo and speedo are a little off? I mean so what if you're doing 62 and it shows 60?
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
Yazovets is offline   Reply With Quote
