Need help!! (Courtesy Light & LED's) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-06-2007, 07:13 PM   #1 (permalink)
Hawaiian Camry
View its2good's Photo Gallery
well here's the situation:
i tried to install LED's that turn on when u open ur driver/passenger door. And to do this, i "planned" on mounting it to the courtesy light's power(red) and ground(orange w/ silver stripes)... Well i discovered the constant power wire underneath the door sill but i could not find the power wire to the courtesy light. Now don't get me wrong, i know which plug in the foot panel goes to the courtesy light, but that red wire was not giving off any voltage (with the door open of course). I tried mounting the LED's power wire w/ the constant power wire and grounded it. This worked but would not turn off when the door was closed (hence the discovery of the constant power wire ) . I decided to do this another day because it was too hot outside, so i connected all the wires back together the way they were before and now the courtesy lights do NOT work both driver and passenger sides.... If you guys could give ur input of what i forgot to do that would be very helpful... thanks
its2good is offline   Reply With Quote
Old 04-07-2007, 12:32 AM   #2 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $304005
View MrSo0h0o's Photo Gallery
im assuming you didnt connect the battery since u needed it to be connected to check for voltage... sooo, have u checked your fuses? maybe you accidentally touched an exposed wire to a piece of metal and shorted the fuse.. thats always the first place to look..
MrSo0h0o is offline   Reply With Quote
Very interesting... NH05TACOMA 2nd Generation (2005+) 52 04-08-2008 06:20 PM
brake light on dash,, GO AWAY!! alieneyed Celica Forum 13 01-06-2005 01:15 PM
AE92 trunk light mod homeguard Archived Corolla threads 25 04-18-2004 05:50 AM
