Fuel problem..need help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-07-2007, 10:18 AM   #1 (permalink)
View massivegrk's Photo Gallery
have a 2002 camry and it idles fine but stepping on the gas pedal does nothing..flooring it only has a minimal effect. the check engine light comes on and the code read by the scanner is p0001 fuel volume regulator control circuit open ...Does anyone have any idea what it could be? Thanks
massivegrk is offline   Reply With Quote
Old 04-08-2007, 10:40 AM   #2 (permalink)
anyone?
Old 04-08-2007, 01:09 PM   #3 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
If you're going to work on the car yourself you should get a manual.
What does the manual say?
What's the fuel pressure? Is the regulator leaking?
If you don't know the answer to ANY of these questions bring your car to the dealer.
Codes just give you direction, you still have to do the manual diagnosis.
You've performed the first two steps of diagnosis. (1) Verified/duplicated concern (2) Check for codes. There are alot more depending on what the diagnostic procedure for that code is. You NEED a manual to seriously diagnose/repair any car. Technicians use manuals and factory online manuals EVERYDAY.
Good luck. If you have a manual and need help just post the questions.
2006 Camry LE Special Edition
Old 04-09-2007, 05:12 PM   #4 (permalink)
Gameroom cash: $303755
There are Toyota factory service manuals are stickied at the top of the General Camry Discussion Forum. They are available for free downloading.
Mike
WTF! 2007 Camry SE Only Giving Me 263.7 mi WITH Full Tank! LunarMist 5th & 6th Generation (2002-2006 & 2007-2011) 262 01-15-2011 01:17 PM
2001 Corolla Starting problem - Fuel Filter theguy 8th Generation (1998-2002) 6 12-31-2008 10:42 PM
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 11:49 AM
'93 pickup on 3 of 4 cylinders, possibley fuel problem? monroe 89-95 Toyota Pickup/Hilux 2 04-30-2006 07:15 PM
Fuel or Electric problem racerui Tercel, Paseo, Starlet, and Sera Forum 2 06-06-2005 05:27 PM
