XM Satellite Radio - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-07-2007, 08:59 PM   #1 (permalink)
View pompanoguy's Photo Gallery
XM Satellite Radio
On my radio, there is a button called "Satellite". I understand that this is for XM. I have a XM unit. What is the Satellite button for? Is there an XM radio already installed in my 2006 Solara?
pompanoguy is offline   Reply With Quote
Old 04-07-2007, 09:17 PM   #2 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Gameroom cash: $149932
View Yazovets's Photo Gallery
Well there's two ways of installing satellite radio...be it XM or Sirius.
One way is the clean, proper way. This means wiring the tuner behind the dash, and using the stock radio's controls supposing it is SAT-ready.
The other way, also known as the ugly way...is to buy one of the external separate radios or receivers. Then you use an FM modulator to feed a radio signal to your stock radio. Or you can plug into your stock radio's input port if it has one. Keep in mind, you have to find a way to mount that ugly aftermarket receiver somewhere.
Anyway, if your radio has a Satellite button, and you have the proper installation (option 1), then it will switch the play mode to satellite radio.
If you have the ugly installation (option 2), then the Satellite button on your radio will not do anything.
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
Yazovets is offline   Reply With Quote
Toyota to Offer XM Radio as a Factory-Installed Option EKam Toyota News 1 08-17-2011 06:53 PM
XM satellite radio installed NewAvalon06 3rd Generation (2005-2012) 7 02-14-2008 03:55 PM
XM and Sirius expected to merge PigsEye Off Topic 13 02-19-2007 10:15 PM
XM Satellite radio for 2005 Highlander Limited adamscrnr 1st Generation (2001–2007) 1 04-25-2006 11:31 AM
FS: Delphi XM MyFi Portable Satellite Radio Unit **MINT** 95CamBoy Non-Automotive 2 05-22-2005 03:25 AM
