It amazes me how Toyota doesn't advertise a lot of the technology built into it's products.
You had to go through the shop manual to find out that the Automatic temp control system in the XLE and others uses a artifical intellegence neural network logic program to control the temp. The AC compressor is a continuous variable design to reduce load on the engine.
Another one I just stumbled across is that alternator has a acoustically decoupled pulley to reduce the "noise" of accessories coming on line.
I wonder what other magic lurks under the hood that buyers are not aware of?
On edit I forgot the Active engine mount system to reduce vibration and noise at idle.
A 3-point support on the front sub-frame is used. An active control engine mount is used on the front engine
mount and a liquid-filled compound engine mount is used on the right and left engine mounts to realize low
noise and vibration and to achieve high levels of both riding comfort and drivability.
2008 Highlander Limited AWD, Silver, SmartKey, VSC/TRAK, Bluetooth, Remote Start, No Nav, Tow package/hitch/color matched fascia, roof rack cross rails, Color keyed mud guards, Camry trumpet horns
What amazes me also is the 2007 V6 Camry uses the first (?) 6-speed automatic transmission with the top two gears overdrive. That's how this 3500 pound V6 can get the advertised 31mpg on the highway. Depending how much you paid the vehicle contains some of the most current technology normally found on luxury high end vehicles....throttle by wire, tpms, 6-7 airbags, ultra low emission engine, etc.
__________________ 2007 V6 Camry LE
Desert Sand Mica
16" Alloys with McGards
Vin #035xxx
Kentucky Build Date 03/07
I'm impressed by the tranny, too.
I did a test on the highway, you can go very slowly in 6th gear.
I did 80km/h (50MPH) at roughly 1000rpm only in 6th gear. That is CRAZY!!!
__________________ 2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
I'm hoping i'll find out they built in the electric-acoustic/sonic women atttractant device built into the passenger seat
damn...but what would happen if there are two identical camrys in the same vicinity?
want one any way!...can always use the flux capacitor to flux her first
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
They've actually done somewhat similar to that for Lexus LS model by putting the massage on back seat. Back in 2001, I saw one couple walked in Lexus dealer, the SMART saleman told the wife to seat in the back and turned on the massage and BOOM the couple put in the order for LS430
