Dash Rattle - Found it - Need Help to remove dash piece - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-14-2007, 06:31 PM   #1 (permalink)
View CheapChic's Photo Gallery
Hi
I found a new rattle in my 1 week only 07 camry. It is the center dash section that houses the clock and the security idot lights and other.
I want to remove it, and it feels like it will pop off, (oblong dash pices) but i am afraid of breaking something.
Does some please have shop drawing of where the clips are and how to remove it.
I would grealy apreicate it.
BOY IT IS ASHAME THIS CAR HAS SO MANY RATTLES. BUT i WILL FIX THEM MYSELF.
THANKS
CheapChic is offline   Reply With Quote
Old 04-14-2007, 06:39 PM   #2 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Gameroom cash: $149932
View Yazovets's Photo Gallery
Rattles and creaking are a perfectly normal thing to happen to a car regardless of age. You're wasting your time. You'll cover this one, and another one will come up.
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
Yazovets is offline   Reply With Quote
Old 04-14-2007, 06:48 PM   #3 (permalink)
The Biggest comment Whore
Avalonman's Avatar
View Avalonman's Photo Gallery
You can always take it in to the dealer, and make them fix it.
Avalonman is offline   Reply With Quote
Old 04-14-2007, 06:51 PM   #4 (permalink)
my dealer has morons working there. they can't even take a tire off.
Old 04-14-2007, 07:20 PM   #5 (permalink)
View Squint's Photo Gallery
It just pulls out but there are still wires connected so don't go nuts.
It's probably not the source of the rattle though.
Squint is offline   Reply With Quote
Old 04-14-2007, 07:22 PM   #6 (permalink)
View rsjyss's Photo Gallery
Find another dealer then.... There is TSB's out there for creeks and rattles. There's a fan grille unit that needs to be changed and windshield clips etc. Dropping the car off Monday to fix this TSB amongst other minor TSB's
If you want to do it yourself... find the TSB here by doing a search. That's if your problem is exactly what's defined in the TSB but you are going to need the parts so.... better just find a decent dealer to fix it.
07 SE V6 Titanium Silver w/Blk Lthr.+ Navi (Option D)
!95 Impala SS - 383 CID, Built 4L60E w/Vig. 4000 Stall, Porsche GT2 Monoblock F/R Brakes, Full Suspension-(Hal 12way Adj. Shocks, Hotchkis, Global West, Eibach), G. LT Headers/Borla/Random Tech +many more mods 12.1@114 MPH@4300lbs
rsjyss is offline   Reply With Quote
Old 04-14-2007, 07:30 PM   #7 (permalink)
can you direct me to the tsb please
thanks
what is a fan grille
Old 04-14-2007, 11:41 PM   #8 (permalink)
thanks
If you read the forum.. the very first thread has a sticky for TSB's. It's not all of them but there is a rattle/tick one which involves clips.
In side the dash there is supposedly a fan grille that makes noise as well.... as per the tech and there is a felt kit that is out to quiet things down too.
Again.... how are you going to be able to do these things yourself without the parts?
Good Luck!
Old 04-15-2007, 08:28 AM   #9 (permalink)
I really don't think mind is the windshield issue
Mine is comming from the center dash section that houses the clock.
Old 04-15-2007, 09:11 AM   #10 (permalink)
my MPG>yours
View kriskraut's Photo Gallery
Yeah, it just lifts straight up. I put padding under there too.
07 TCH
kriskraut is offline   Reply With Quote
Old 04-15-2007, 11:24 AM   #11 (permalink)
Gameroom cash: $303755
Did the padding actually take car of the rattle? If it did, what type of padding did you use?
Thanks.
Mike
Old 04-15-2007, 11:29 AM   #12 (permalink)
MDT Toyota Tech
View BadChicken's Photo Gallery
at least the whole dash comes out fairly easy on the new camry, i've had a few out to refelt the front portion already
BadChicken is offline   Reply With Quote
Old 04-15-2007, 12:29 PM   #13 (permalink)
thanks what I am doing. what parts did you do
isn't it a shame you have to do this on a brand new car.
Old 04-15-2007, 02:35 PM   #14 (permalink)
MDT Toyota Tech
i removed the whole dash
I don't mind doing it when Toyota's paying me good money to do it
Old 04-15-2007, 04:06 PM   #15 (permalink)
07 Camry XLE V6
View ghymes's Photo Gallery
I'm taking mine in Tuesday to get this darn rattle fixed. It's so annoying. The first time they had it there, they said the couldn't duplicate it. What a bunch of BS. Then the car got dented in their parking lot - which they will fix. Bummer.
2007 Camry XLE V6 - 6 speed Auto - NAV - VSC - Smart Key - Fog lights - Dual Chrome Exhaust - Glass Breakage Sensor System - Heated Grey Leather Seats - Barcelona Red Metallic
ghymes is offline   Reply With Quote
Reverse wire signal for navigation...can it be found in the front dash? djpeetur 5th & 6th Generation (2002-2006 & 2007-2011) 46 01-06-2012 04:57 PM
Dashboard Separation twoseam 2nd Generation (2005+) 10 11-18-2006 10:15 AM
Seat belt rattle cause found - what to do now? MikeX 2nd Generation (2005+) 26 05-05-2006 08:23 PM
Removing top big interior piece. gqdabien Camry & Solara Lounge 1 09-30-2003 03:44 PM
