Muffler Install - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-18-2007, 03:25 AM   #1 (permalink)
Camry 03 Sportivo
View poohbear's Photo Gallery
Gen5 Muffler Install
Thinking of getting some new mufflers for my gen5 camry.
Are they relatively simple to install? or does it require special tools?
Thanks
poohbear is offline   Reply With Quote
Old 04-18-2007, 12:15 PM   #2 (permalink)
Webb26's Avatar
View Webb26's Photo Gallery
Depends if you have a universal muffler or an axle back. Axle back will be an exact fit, key word suppose to be, if and only if you have a model specific axle back. IF not you would have to chop off your muffler after the flange, and somehow weld the new muffler to the pipe you just chopped off.
Webb26 is offline   Reply With Quote
Old 04-18-2007, 01:30 PM   #3 (permalink)
BANNED
View w203's Photo Gallery
If you are talking about the universal mufflers that only add sound and nothing else then yes your gonna need a welder. If you don't have access to them your local welding/muffler shops should have them ie Midas etc. My friend got one installed for 80 dollars, so that should give you an estimate.
w203 is offline   Reply With Quote
Old 04-18-2007, 08:35 PM   #4 (permalink)
Camry 03 Sportivo
Well the dealer said the muffler is a direct replacement and no welding needed.
so it should be DIY-able, thanks guys
Old 04-18-2007, 09:54 PM   #5 (permalink)
BANNED
If its a direct bolt on then it is an axel back or a catback exhaust. Not a muffler.
Old 04-19-2007, 12:40 AM   #6 (permalink)
Camry 03 Sportivo
Its something like this ..and the dealer said the difference lies within the internals...
Old 04-19-2007, 01:35 AM   #7 (permalink)
Webb26's Avatar
you nailed it. I think, well at least from what poohbear is saying, he will be purchasing an axle back.
Old 04-19-2007, 04:57 AM   #8 (permalink)
Camry 03 Sportivo
So i'm a noob at this but can someone clarify what's the difference between muffler and a axel back? i thought everything after the exhaust pipe is the muffler...
The dealer said that this sportivo muffler has the same fittings as original bolt on flange...
Thanks guys...
Old 04-19-2007, 11:06 AM   #9 (permalink)
Webb26's Avatar
^ this has already been said in tangerine and my posts. BUt to clarify even more. Muffler is the actual muffler body component. Axle back includes the piping and hanger bars allowed to make the install a a direct bolt on. Mufflers need to be welded on because they have nothing but the actualy muffler canister. For example. if you buy a magnaflow muffler you will have to get it welded on. ON the other hand, TRD has an axle back which is the direct bolt on.
Old 04-19-2007, 10:20 PM   #10 (permalink)
BANNED
A regular muffler should look like this
A catback exhaust should look like this:
The main differences would be the extra piping that were made to be a direct bolt on to the existing mounts.
The muffler shown above is just one type of the muffler, there is a chambered, straight through as well as a twin loop.
Old 04-19-2007, 11:06 PM   #11 (permalink)
Gameroom cash: $203160
View CamrySExxx's Photo Gallery
^ forget that garbage... get this
CamrySExxx is offline   Reply With Quote
Old 04-20-2007, 02:30 AM   #12 (permalink)
The Cool Guy
Super Kaioken's Avatar
View Super Kaioken's Photo Gallery
^ wow that is obnoxious, it'd be cool if it were a jet engine though
-Custom 2.5in Cat-back Exhaust + Borla Muffler + Weapon R Dragon Intake + TRD Rear Sway Bar + TRD Springs + TRD Front Strut Brace
Super Kaioken is offline   Reply With Quote
Old 04-20-2007, 09:16 AM   #13 (permalink)
Camry 03 Sportivo
I understand now, thanks for all the info guys
Muffler shop cannot install a universal muffler due to fact. muffler design???? bennington28 3rd & 4th Generation (1992–1996 & 1997–2001) 17 02-13-2007 07:50 PM
What kind of aftermarket muffler should I install? nogard 1st & 2nd Generation (1983–1986 & 1987-1991) 3 01-24-2007 09:04 PM
help !! Muffler install in toronto pk_kk Camry & Solara Lounge 3 06-09-2005 10:34 PM
5sfe Engine Install xylium 3rd & 4th Generation (1992–1996 & 1997–2001) 9 04-08-2005 02:07 AM
Rod Millen 92-94 Add-on Install Zer05 3rd & 4th Generation (1992–1996 & 1997–2001) 3 10-28-2003 10:25 AM
