scheduled maintenance - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-20-2007, 12:54 PM   #1 (permalink)
View biffman's Photo Gallery
I have a 2002 Camry LE (2AZ-FE) auto, with 91,000 miles. Is there a scheduled maintenance for the water pump and thermostat, and should I replace the belt tensioner when I replace the serpentine belt? Also, the service guide says that the plugs don’t need to be replaced until 120,000, but the dealer said they recommend changing them at 90,000? Any help would be greatly appreciated!
biffman is offline   Reply With Quote
Old 04-20-2007, 12:59 PM   #2 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Gen5
As your waterpump is not timing belt driven I would replace it when it starts to leak.
I really haven't seen how long the iridium plugs will last. Platinum plugs in my GM were supposed to go for 100,000 miles but at around 60,000 miles I would start losing the platinum. I will probably replace my iridium plugs in my Camry 2AZ-FE at about 100,000 miles.
You only replace the serpentine belt tensioner when there is a problem with it.
Replacing the thermostat would be good preventative maintenance if it's easily in your finances. There is no recommended interval but the cost of the thermostat is very little compared to severe engine damage it can cause if it malfunctions.
Go by the factory manual and check over the vehicle to see if anything else should be done.
I would recommend cleaning the throttle body for sure though.
2006 Camry LE Special Edition
Old 04-20-2007, 06:17 PM   #3 (permalink)
Gen5
Thanks TRD VVTI, I will check the factory manual.
Where's a good place for scheduled maintenance in NYC? busyba General Discussion 0 03-29-2006 01:06 PM
Scheduled Maintenance Guide JMSinMD Camry & Solara Lounge 1 11-29-2005 09:55 PM
Stupid Q: Where can I find a Scheduled Maintenance List Lumberg Camry & Solara Lounge 6 11-28-2005 12:20 PM
scheduled maintenance? English Tom Archived Corolla threads 9 11-27-2005 04:47 PM
How much scheduled maintenance is really necessary? deadeye Archived Corolla threads 2 11-09-2004 05:31 PM
