Hid Wiring installation Need Help Please Guru Needed - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-20-2007, 09:35 PM   #1 (permalink)
View CheapChic's Photo Gallery
Hi
I am hooking up my hids and need help
on the ballast side that connect to the stock harness with a cap connection, it has a black and a red wire that I will attach pins to. I would say the black is ground and the red is positive.
on the factory harness that plugs into the stock halogen, one the passenger it is white and black, on the drivers side it is white and brown.
which is which.. please thanks a ton...
CheapChic is offline   Reply With Quote
Old 04-21-2007, 04:10 AM   #2 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Gameroom cash: $455050
View Luna2's Photo Gallery
Gen6 Low Beam Headlamp wire colors polarity
Originally Posted by CheapChic
Hi
1st. the ground (return to battery) wires should be "white with black tracer" on all lamps.
2nd. the 12v power (source [switched & fused] from battery) is a "solid" black, which is the RH low beam.
3rd. the 12v power (source[switched & fused] from battery) is a "solid" brown, which is the LH low beam.
Source:
http://www.camrymanuals.com/manuals/07/07EWD.pdf
page 447
Questions should include most vehicle details, to help eliminate errors because of model/level/engine/tranmission/and heat/cool system differences.
Enjoy the HID lights, and please remove the "squirrel spotters". "Be kind to your fellow drivers, first"
2011 XLE, I4, AT, Sliver, New May 1, 2010
MFG 02/25/2010
Stock, Shucks!
"Kinda Hard to ID in a Parking Lot"
Luna2 is online now   Reply With Quote
Old 04-21-2007, 07:09 AM   #3 (permalink)
Source:
page 447
so the white is not the positive and the black is not the negative????
on my ballast, it has a black and white. the instructions suck...whick do you think is the ground. black
Old 04-21-2007, 07:31 AM   #4 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Gen6
Source:
page 447
This makes item #2 "black" and #3 "brown" on my last post +12v DC (switched of course).
If you try to think like TOYOTA, vehicle electrical work is made a lot simpler.
Your ballast instructions should tell you which is + plus. Tell me what your install instructions say, and I will tell you how to connect to the factory harness.
MFG 02/25/2010
Stock, Shucks!
Old 04-21-2007, 07:51 AM   #5 (permalink)
kissess you are a doll
I think i have the wrong instructions.
it say the white is + and the black is negative on the ballast
but****
my wires are acutally red and black on the ballast part the ties into the stock harness
Old 04-21-2007, 08:03 AM   #6 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Gen6 HID Wiring?????
Well
1st. Are the new bulbs "hard wired" to the ballast?
2nd. Who makes the kit? Model #? Do the have a web site with the install instructions?
I believe at this point the black ballast wire connects to the factory harness "white with black tracer" which is ground.
This would make the ballast red wire +12 volt source.
I would like to verify. A pix might help.
MFG 02/25/2010
Stock, Shucks!
Old 04-21-2007, 08:19 AM   #7 (permalink)
Well
hugs, they work
i will post picture later inthe week of my chic hid install
Old 04-21-2007, 08:20 AM   #8 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Gen6
Great!!!!!!!
MFG 02/25/2010
Stock, Shucks!
The #1 Techone HID Kit 6000k/8000k/10000k/12000k... $250 SHIPPED! Mod-Express Supporting Vendor Sales 53 11-27-2007 12:38 PM
Consumer Reports on HID Phi General Discussion 28 01-17-2007 08:23 PM
hid kit for sale oklalala Car Parts for Sale 6 12-15-2006 11:21 AM
Real HID's not necessarily "better" fredster34 5th & 6th Generation (2002-2006 & 2007-2011) 26 12-11-2006 06:06 PM
HID Kits Questions (56k Warning) AznVR4 Camry & Solara Lounge 29 06-29-2006 10:10 AM
