Loud ticking sound on cold start up - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-23-2007, 01:10 AM   #1 (permalink)
Camry Gen5er
zettahertz's Avatar
View zettahertz's Photo Gallery
There's some loud ticking sound/vibrating sound on a cold start up coming from the serpentine belt/pulley area that just started 2 days ago after a 3 hr drive (some hard driving involved), but disappears after warming up and it's never had this sound b4. What can it be? Loose belt? or something more serious?
O yeah... forgot the important part. There's only that sound when it is put on Reverse/Drive gear and braked. So it sounds fine when it's on Park or Neutral.
2002 Camry LE I4 4AT
Spoiler, front strut bar, 17" wheels, Viper 791xv remote start alarm, Injen SRI, 50%-15% tint, TRD Exhaust, Tein S-tech, NST pulleys(underdrive + accessories), Whiteline RSB, HID+TSX projector retrofit.
2007 Nissan 350Z Grand Touring 6MT w/ Navi
zettahertz is offline   Reply With Quote
Old 04-23-2007, 01:46 PM   #2 (permalink)
View marc780's Photo Gallery
If the ticking is only coming from the belt and not the engine itself? Carefully check your belts, some of the ribs may be cracked or broken off the inside portion.
Spray some silicone spray on the belts, one at a time, then start the engine when its cold and listen. Noise gone? Replace belt. Noise still there? Check other belts the same way.
If the tick is still there after this, maybe you just need to change your timing belt, or maybe it is the alternator or other acc.
Old 04-23-2007, 03:17 PM   #3 (permalink)
Camry Gen5er
zettahertz's Avatar
hmm, something makes me think it's not the belt. 'cus I've changed the belt at 45K (now at 65) and all it made was a squeaking noise that never goes away even when the car is warmed up. And this sound only occurs when there's a load, and I don't hear it when i just put it to park/neutral and press the gas. It's very difficult to pinpoint exactly where the sound is coming from. Very strange...
Old 04-24-2007, 01:03 AM   #4 (permalink)
Another way to test to see if the noise is in fact from a belt, or a belt-driven accesory. Remove the belt, one belt at a time if you dont have a serpentine type belt. Then run the engine and listen again. (You can run the engine with no alternator belt for a minute or two and it wont hurt anything.) If the noise is unchanged with the belt off, maybe it is your timing belt making the noise?
Old 04-24-2007, 01:28 AM   #5 (permalink)
Webb26's Avatar
View Webb26's Photo Gallery
Zettahertz....how loud is this ticking sound? Regardless, as little as i do know about this problem, my friend has a problem similar to your description. His highschool auto teacher, after a couple compression test, said that it couldn't have been a blown piston, worn rings or anything of the sort, and his teacher as well as some local mechanic said that it probablt was a lose piston pin or something like that. As soon as i can talk to him, i'll find out more of his problem and let you know
Webb26 is offline   Reply With Quote
Old 04-24-2007, 03:38 AM   #6 (permalink)
Camry Gen5er
zettahertz's Avatar
dang, loose piston pin, seems kinda serious. better not be caused by the pulley.
It's like some vibrating sound from the passenger side. The first time it was kinda loud, u can hear it if it's idling (set to R and braked) w/ windows down and probably like 10 ft away the first time it happened (was parked outside).
It seems like the car has to be TOTALLY cold to make that sound. I drove at like 12PM (parked in garage), minor sound, can barely tell it's there. Then 6 hrs later... turned it on again, no vibrating. It was much louder when I parked outside overnight.
This engine uses a timing chain i believe. How often do u have to replace that thing? I'd expect it to be longer than the timing belt, and 65K seems like a pretty short time.
Old 04-24-2007, 04:57 AM   #7 (permalink)
Camry Gen5er
zettahertz's Avatar
man, looked up some of the "noises" that a messed up engine can make and this is what i found:
http://books.google.com/books?id=U4T...ENSQ#PPA198,M1
interesting book quite interesting i'd say...
Piston Pin Knock: "originates in upper portion of the engine and most noticeable when engine is idling and when engine is hot". That's kinda contrary to the symptoms cus it seems to happen when it's cold... very cold.
Old 04-24-2007, 11:46 AM   #8 (permalink)
Webb26's Avatar
I Was going to add...that my friends car that has the piston pin knock, mostly occurs when the engine ie warm. So maybe your problem could be different, or not as severe.
Starter noise at cold engine start? canuck1 5th & 6th Generation (2002-2006 & 2007-2011) 107 03-08-2012 01:35 PM
cold start knock gasgas300 2nd Generation (2005+) 9 01-18-2007 08:36 PM
hot engine wont start but cold OK dejohn Camry & Solara Lounge 13 01-27-2006 01:29 PM
price on 2 gen cold start injector? spills1969 Camry & Solara Lounge 1 07-22-2003 11:32 AM
Cold Start Switch 86CRESSIDA86 General Discussion 7 01-07-2002 10:10 PM
