ign kill swi installed--- - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-24-2007, 11:45 AM   #1 (permalink)
carlo$'s Avatar
View carlo$'s Photo Gallery
click here:
http://www.cardomain.com/ride/2379797/16
2005 LE 4 cyl
carlo$ is offline   Reply With Quote
Old 04-24-2007, 12:51 PM   #2 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Gameroom cash: $149932
View Yazovets's Photo Gallery
What is the point of an ignition kill switch when you can just turn the key?
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
Yazovets is offline   Reply With Quote
Old 04-24-2007, 01:02 PM   #3 (permalink)
carlo$'s Avatar
when the switch if off the ignition is totally disabled.
if a thief tries to hotwire the car nothing happens.
unless he knows exactly which wire was bypassed the car can not be hotwired.
i guess he could jump start the starter.
2005 LE 4 cyl
Old 04-24-2007, 11:13 PM   #4 (permalink)
BANNED
View w203's Photo Gallery
Or go straight to the source and just hotwire them.
It should deter away amateur thieves but not the experts. Every security measure can be bypassed. So far the only one I've encountered that've claimed not to be bypassed (which I have no experience with) would be the Ravelco.
w203 is offline   Reply With Quote
Old 04-25-2007, 11:40 AM   #5 (permalink)
View witxp's Photo Gallery
I've read on another forum someone actually used a starter kill type setup to cut power to the fuel pump. That might be a better alternative.
witxp is offline   Reply With Quote
Old 04-25-2007, 12:47 PM   #6 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
That's a good idea to target ignition-unrelated components.
Old 04-25-2007, 07:09 PM   #7 (permalink)
BANNED
That would be a fuel kill switch. Disconnect the power or negative going into the fuel pump which disables it from starting. As I've said before, still can be bypassed vai the source but still a good measure.
Old 04-25-2007, 07:43 PM   #8 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
A fuel cut off would probably be a better way than to cut the starter on my car.
I can start my car with a dead starter if I had to.
2007 Camry 2.4L 5M
Old 04-25-2007, 08:06 PM   #9 (permalink)
Dominican Republic
Dj-torn's Avatar
View Dj-torn's Photo Gallery
Thats a great idea, and my shop has done many for people, who don't want alarms but need some safet. But that switch is WAY to bulky;
We used valet push switches; High Beams; Low Beams; Parking Lights, Parking Brake, Brakes Lights, Turn Signals, Wipers, and others.
Most of the times its a combination. Light button and lights.
Stock 2002 Camry LE: 2AZ-FE: VVT-i
Dj-torn is offline   Reply With Quote
Installing kill switch toytrain13 Camry & Solara Lounge 2 05-04-2006 03:51 PM
turbo timer and kill switch Fred4agte Audio, Video, and Security - Tech 1 12-22-2005 05:22 PM
Can 2k4 4Runner come with factory installed alarm? njchen24 4Runner Lounge 2 11-21-2003 12:57 PM
Do your car has factory installed alarm or an add-on later? njchen24 General Discussion 7 11-08-2003 11:16 PM
upgrade harness installed ...but not working _VVTi_ Camry & Solara Lounge 7 10-18-2003 09:32 PM
