this is how you change your plugs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-25-2007, 01:00 PM   #1 (permalink)
carlo$'s Avatar
View carlo$'s Photo Gallery
click here:
http://www.cardomain.com/ride/2379797/17
2005 LE 4 cyl
carlo$ is offline   Reply With Quote
Old 04-25-2007, 01:34 PM   #2 (permalink)
Gameroom cash: $203160
View CamrySExxx's Photo Gallery
diy instruction? how about putting it back and such. its simple but would help people who dont know how to
CamrySExxx is offline   Reply With Quote
Old 04-25-2007, 01:42 PM   #3 (permalink)
carlo$'s Avatar
i dont follow you, put it where?
2005 LE 4 cyl
Old 04-25-2007, 01:46 PM   #4 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
I think he meant installation of the plugs afterwards.
2007 Camry 2.4L 5M
Old 04-25-2007, 01:46 PM   #5 (permalink)
View onsknht's Photo Gallery
I think he means reassemble... Things like.
1. Torquing the plugs
2. Reinstalling the coils
3. Reinstalling the cover for the valve cover
IMO - if you can get it apart, you can get it back together... Usually they tell you to reassemble in reverse order of disassembly, which doesn't repeat the steps, but some folks need their hand held the whole way.
2GR-FE
onsknht is offline   Reply With Quote
Old 04-25-2007, 02:04 PM   #6 (permalink)
carlo$'s Avatar
aahhhhh!
2005 LE 4 cyl
Old 04-25-2007, 02:20 PM   #7 (permalink)
yea thats what i ment. just a suggestion since some people will need more detailed instructions if its like their first time. You title is kind of misleading since you just take the plugs out .. catch my drift?
Old 04-25-2007, 02:39 PM   #8 (permalink)
Especially if they tend to be the kind of people that have all kinds of extra parts after reassembling something
2007 Camry 2.4L 5M
Old 04-25-2007, 02:46 PM   #9 (permalink)
eflw1029's Avatar
View eflw1029's Photo Gallery
Gen6 You got a write-up for the V6 doing the rear plugs?
Carlo$-
You are one of the most prolific posters on this forum and I was hoping you had a writeup how to get to the rear plugs on a V6...got something along those lines? Short of physically removing the upper plastic resin intake I can even get my hands to the rear cylinder head to even feel for the three (3) "coil on plugs"!
2007 V6 Camry LE
Desert Sand Mica
16" Alloys with McGards
Vin #035xxx
Kentucky Build Date 03/07
eflw1029 is offline   Reply With Quote
Old 04-25-2007, 03:24 PM   #10 (permalink)
carlo$'s Avatar
sorry, i have a 4 cyl. nothing on v6s. i hope one of our other brothers can post some pics for you.
good luck.
2005 LE 4 cyl
Old 04-25-2007, 03:50 PM   #11 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352460
View gdanaher's Photo Gallery
Gen6
In amateur radio, we call it Elmering--having an experienced person hold your hand and show you how to do things, imparting knowledge all the way. Nobody seems to know how to turn a screwdriver these days, so I would suggest to anyone needing step by step directions on how to replace a spark plug, that they get themselves an old junk lawn mower and proceed to disassemble the engine, laying the parts out on the work bench, and then clean the mess up and reassemble the thing, remount it on the frame and go mow the lawn. Sometimes you just have to learn by doing, and maybe practicing on something worthless that can be chunked would be a first step.
gdanaher is offline   Reply With Quote
Old 04-25-2007, 04:08 PM   #12 (permalink)
ToyotaNation Member
View Burnes's Photo Gallery
I foresee used mower sales on the rise....soon!
2007 Camry LE I4 Titanium
http://www.cardomain.com/ride/2637672/1
Burnes is offline   Reply With Quote
Old 04-25-2007, 06:40 PM   #13 (permalink)
Just get a Haynes manual. The instructions are fairy clear and an abundance of photos are provided.
2007 Camry 2.4L 5M
Old 04-26-2007, 07:19 AM   #14 (permalink)
summerwind's Avatar
Gameroom cash: $448930
View summerwind's Photo Gallery
Two points not stated.
1) you need to use anti-seize compound on the new plug threads before installing them.
2) if you use a spark plug socket with the rubber insert, I have found that putting a small piece of masking tape on the end of the extension before you connect it to the socket helps keep the extension and socket together when you try to remove it.
If the fit between the socket and the extension is loose you will end up with the socket staying on top of the plug and only removing the extension after you tighten the plug.
The farther the plug is in the cylinder head the more fun it is to try and get the socket out
2008 Highlander Limited AWD, Silver, SmartKey, VSC/TRAK, Bluetooth, Remote Start, No Nav, Tow package/hitch/color matched fascia, roof rack cross rails, Color keyed mud guards, Camry trumpet horns
summerwind is online now   Reply With Quote
Old 04-26-2007, 01:18 PM   #15 (permalink)
ToyotaNation Member
Gen6
The manuals are not out yet and won't be for a few years, right?
How to change spark plugs on 1MZ-FE under 1 hour albertezza Camry & Solara Lounge 25 06-23-2011 08:51 PM
Spark Plugs - How hard can it be? 95t100xcb T-100 7 07-28-2007 07:53 PM
'96 Avalon Timing Belt Change Advice Brown Bear 1st Generation (1995-1999) 1 09-06-2006 12:37 AM
funny oil change docktortal33 2nd Generation (2005+) 7 08-08-2006 03:17 PM
spark plugs cam01speak Camry & Solara Lounge 10 01-24-2006 12:27 PM
