Parking brake adjust - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-27-2007, 01:54 AM   #1 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
I found some instruction on adjusting my parking brake, but they're not very clear.
What is the shoe adjust hole plug?
2007 Camry 2.4L 5M
Old 04-27-2007, 07:41 AM   #2 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
It should be in the rotor, where the wheel mounts.
2006 Camry LE Special Edition
Old 04-27-2007, 10:12 AM   #3 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $186325
View JSM1284's Photo Gallery
The plug is on the back of the backing plate, it should be rubber, or it may be a metal peice you need to tap out.
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Old 04-27-2007, 01:58 PM   #4 (permalink)
TRD VVTi's Avatar
Ooops. Sorry, I get them mixed up sometimes.
Old 04-27-2007, 02:15 PM   #5 (permalink)
Thanks for the replies. I kept scrolling through the manual and found what I needed.
2007 Camry 2.4L 5M
Old 04-27-2007, 03:43 PM   #6 (permalink)
TRD VVTi's Avatar
I was right then.
Old 04-27-2007, 11:06 PM   #7 (permalink)
I think JSM might have been thinking of drum rear brakes. My 00 had drums in the rear and the adjust was on the backing plate IIRC.
2007 Camry 2.4L 5M
Old 12-09-2007, 10:18 PM   #8 (permalink)
I finally got around to adjusting the parking brake on my car some 8 months later.
Anyhow, the diagram for the adjuster is backwards or I'm looking at it wrong. To expand the shoe, you push the teeth facing you upwards. In the diagram, if you rotate the screwdriver in the direction of the arrow it would work - to me it looks like that's the direction that the adjuster is supposed to rotate.
2007 Camry 2.4L 5M
Old 12-10-2007, 09:23 PM   #9 (permalink)
View i 1a 05 Camry's Photo Gallery
is this procedure the same for gen 5.5 or its only for gen 6?
i 1a 05 Camry is offline   Reply With Quote
Old 12-10-2007, 09:26 PM   #10 (permalink)
I took the above diagrams from the Gen 6 repair manual. I would suspect that the procedure is similar on Gen 5s.
There is also a procedure to adjust brake handle travel that is omitted from the above diagram.
2007 Camry 2.4L 5M
parking brake drum adjustment - help! lars949 Camry & Solara Lounge 7 05-06-2007 08:28 AM
Where are the parking brake and foot brake lead?? lucanhookup Camry & Solara Lounge 16 03-06-2006 09:50 PM
Parking Brake Shoes Zanteus Camry & Solara Lounge 5 02-10-2006 02:04 PM
gen2 brake light stays on... help... please.. busted_ride 1st & 2nd Generation (1983–1986 & 1987-1991) 2 09-24-2004 04:56 AM
ae86 parking brake. racejockey Archived Corolla threads 16 09-18-2004 05:44 AM
