just take any flat bladed tool (taped up screwdriver works well) and pry the HVAC controls out. its held in by four clips: two on each side near the top/side of the hvac controls, and two near the bottom/side of the controls. i'm not sure what your replacement bulb looks like, but if it has a twist base, just twist out the original and twist in the new one. the bulbs are slightly recessed into the back of the unit, so you will also need a flat blade screwdriver to twist the bulbs in and out.
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
