HELP - High Idle after cleaning Throttle Body - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-28-2007, 09:35 PM   #1 (permalink)
View sundarpn's Photo Gallery
2002 Camry XLE.
I cleaned my throttle body today. Since the throttle plate moves by a motor, in order to keep it open, I turned the key to ON and held the gas pedal down by using some weight.
After I put everything back, the idle was high 2000+, then stays at 1300 to 1400 range
I drove about 10 miles and it is still the same. When stopped at a light in drive, the idle is still 1000
Did I mess up the e-throttle or the throttle position sensor? (Since I used a weight to hold the gas pedal down, I am worried now)
sundarpn is offline   Reply With Quote
Old 04-29-2007, 11:26 AM   #2 (permalink)
Disconnecting the battery for 15 mins to reset the computer solved this. (this was mentioned in an older post) just writing it again so it get s better hits in the search
thx
Old 04-29-2007, 09:15 PM   #3 (permalink)
desi_prodigy's Avatar
View desi_prodigy's Photo Gallery
i have trouble doing this,,cuz it soo hard to get the pipes off,,and especially putting them back on its even harder,but anywayz,,i did the throttle cleaning on ma car by spraying a bottle of throttle body cleaner into it,,and now ma car alwayz idles at 1900-2000,its an inline 4 model 2005 camry,,,and i did take the battery off for about 30minz then put it back on and still same problem,,but i dont see any difference in performance,but it did make a difference in my gas milage,,its weird cuz ma car use to idle at around 1600
desi_prodigy is offline   Reply With Quote
Old 04-30-2007, 11:55 AM   #4 (permalink)
View HarrisH's Photo Gallery
I just experienced the same issue as you sundarpn, exact same issue.
I just took off the battery cable let's hope that fixes it!
HarrisH is offline   Reply With Quote
Old 04-30-2007, 12:49 PM   #5 (permalink)
Yup that fixed it!!!
Not starting after cleaning throttle body 98-Camry Camry & Solara Lounge 9 12-15-2011 01:17 AM
Cleaned Throttle Body....whats With The High Idle?? IvanHoe 1st & 2nd Generation (1983–1986 & 1987-1991) 15 08-15-2006 04:39 PM
throttle body cleaning/ fuel filter MrSo0h0o Camry & Solara Lounge 19 07-30-2005 05:40 PM
Throttle Body Cleaning nobrainer Camry & Solara Lounge 13 06-29-2005 03:02 PM
